Results 1 to 10 of 15
    JK Freak gadget799's Avatar
    Mission BC Canada
    Shifter Knob Removal - Manual Transmission & Transfer Case
    Shifter Knob Removal - Manual Transmission & Transfer Case...
    This was performed on a 2010 model but would assume its the same for 07-10 just proceed with caution just in case..
    Tools Needed:
    Small Flat Screwdriver
    10" Adjustable Wrench (crescent wrench)
    Small Ball Peen Hammer
    Clean Shop Rag..
    Optional:
    Football Helmet with Full Face Guard..(my dentist recommend this option)
    Now
    Use the small flat screwdriver to pop off the bottom caps on each shifter knob (pointed to with red arrows)
    Then take your Adjustable Wrench and size it to just fit the arm of the shifter
    use you shop rag between the shifter arm and your wrench to prevent scratching
    NOW..USE EXTREME CAUTION !!!
    Put on your Optional Football Helmet or have a partner be prepared to catch the knob ??
    use your Ball Peen Hammer and tap UP WARDS on the head of the wrench (NOT SUPER HARD) just enough to persuade it
    and POP it goes ....
    Do the same for the transfer case knob and you are ready to install your favorite aftermarket knob..
    I chose the Drake Offroad Black Billet Aluminum Set .. Great Product very pleased with them...(little chilly to handle in winter)
    Drake Offroad Black Billet Aluminum Manual Shifter
Name:	New MPAC Straddle & Bags 2.JPG
    Drake Offroad Black Billet Aluminum Transfer Case
Name:	New MPAC Straddle & Bags 1.JPG
    ** Not Sure if this method will work on the Automatic Transmission Knob?? **
    Addition:
    if you are installing the Drake Shifter set, you may find that the base of the shifter knob is slight larger than the shift arm... this can be corrected by applying a couple wraps of hockey tape to the arm (just enough to make it a tight fit, then lightly tap the knob with a rubber mallet and tighten the set screw .. this will eliminate any side to side movement causing the knob to come loose..
    Hi .. My Name is gadget799/Trevor and im a Mod-A-Holic ....
    Freaking JK Guru Ludski's Avatar
    Denver, CO
    thanks gadget! adding to the how-to index!
    *THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS*
    JK Videos
    My Build
    Ludnuts Off-Road
    Rock Krawler SpiderwebShade PoisonSpyder
    Quote Originally Posted by jbsmith44 View Post
    ... She told me people like me should be shot and run over with a lawn mower....
    Mission BC Canada
    No Problem Ludski ...my pleasure..
    Love the football helmet idea... LMAO.. you do want to make sure sure chin is out of the way... I know, because I punched myself..
    Mission BC Canada
    YUP... 2 wacks with the hammer and a quick trip to the ER for 3 stitches in upper lip and 1 loose tooth... the knob bounced off my face like those old days at school playing dodge ball
    Denver, CO
    ^^ im right there with you echo. punched myself in the chin too. not fun.
    JK Videos
    My Build
    Ludnuts Off-Road
    Freaking JK Guru Brandon1024's Avatar
    Barrington
    For the transfer case shift knob I have that too but on an automatic guessing them are the same. Whenever I use mine though it comes lose and won't stay tight. Do you have this problem?
    2013 Billet JK | Synergy 2'' Lift W/ Bilstein 5100 | 37x12.50x17 Goodyear MTR/K Raceline Beadlocks | Poison Spider BFH Trail Stinger | Poison Spider BFH Rear Bumper | Poison Spider Rocker Knockers | DIY PSC Hydro Steer
    Mission BC Canada
    Quote Originally Posted by Brandon1024 View Post
    hey Brandon ..
    did you notice the base of the drake shifter is a little larger than the shaft? all i did was apply a couple wraps of Hockey Tape so that when the shifter knob went on it was almost to tight then gave it a light tap down with a rubber mallet and tightened the set-screw as tight as i could without stripping it...
    hope that helps yah out ...
    Senior JK Freak jbsmith44's Avatar
    Florence SC
    This is just not fun... I ended up with a split lip and bloody mouth.... Trim those finger nails first an wear a football helmet lmfao
    "If an injury has to be done to a man it should be so severe that his vengeance need not be feared."
    -Niccolo Machiavelli
    Supporting Freak DeReK_AgIn's Avatar
    Norfolk VA
    This sounds dangerous, im just gonna stick with my normal shift knob it works fine
