Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
  1. #41
    Freaking JK Guru Scooter Scott's Avatar
    McCordsville, IN
    Yup I saw that...just hate how dealers vary on what they will fix and what they won't.
    Kahlo in Noblesville told me they wouldn't fix my leaky lines because that weeping is normal. Dellen in Greenfield said its not normal and promptly fixed it. I know who gets all my warranty work going forward.
    2009 Deep Water Blue Wrangler Unlimited X
    KMC Machetes | 37x12.50x17 Pitbull Rockers | Synergy 3" Coils w/ Rancho 9000XL Shocks
    Currie Antirock | 5.13's | Front ProRock 44 | ARB Air Lockers
    JKS Rear Adj Trackbar| Kenwood DNX7100
    My Build Thread
  2. #42
    Senior JK Freak jk.kenny's Avatar
    El Paso Tx
    Quote Originally Posted by LILWB View Post
    Good to hear. If it starts leaking take it apart and smear some RVT onto the metal tube and then reinstall the heater hose and clamp. Should keep everything nice and dry. I had the same problem. I just cut out the stock cooler altogether and used the same hose to plumb in an external cooler.
    Gonna have to take your advice, left the jeep running this morning for about 20 min before I left to work and had a small drip on my drive way.. also gonna add a second clamp to both sides...
  3. #43
    JK Freak LILWB's Avatar
    Bay Shore, NY
    Ya I have 2 clamps on each hose. Smart move
    Sent from my C771 using Tapatalk 2
  4. #44
    So Cal
    From what Iíve read, they may or may not cover the leaking lines under the recall. But the new stock lines will leak again. I think we all would be better off to repair, replace the hoses ourselves. There seems to be many different solutions to the problem. Personally Iím still researching options, but am going to do the repair myself.
  5. #45
    Quote Originally Posted by Sherfjeep View Post
    From what I’ve read, they may or may not cover the leaking lines under the recall. But the new stock lines will leak again. I think we all would be better off to repair, replace the hoses ourselves. There seems to be many different solutions to the problem. Personally I’m still researching options, but am going to do the repair myself.
    If the hoses or any part for that matter was covered under a recall, then it's always covered. Warranty will cover redo's on recalls over and over
  6. #46
    So Cal
    How did you get the hose over the ridge, where the factory crimp fitting ends. I just did mine but couldnít get the hose over this.
