Results 1 to 10 of 15
    Northern Virginia
    larger tires, backspace, and clearance?
    Considering moving to a 38 13.50 and currently have 4.5" backspacing. I'm at 4" of lift on a 2010 JK unlimited. I've got the body, fender, and bumper issues sorted out, but I'm wondering about clearance behind the tires, specifically the sway end links and the lower control arms (and maybe the frame). The tire is also available in 37 13.50 and about 6lbs lighter, but the 37 is a load range E, whereas the 38 is still a D. The tires are heavy enough already so I prefer not to run a spacer with these two tire options...just don't want to add more stress to the knuckles and related components. Thanks for any insight.
    -G
    One Ton MoFo Heat Treater's Avatar
    Mass
    Quote Originally Posted by JKGA View Post
    -G
    With 4.5 backspacing your going to rub your frame full turned on 38's
    ridin 44's with mud on the doors
    Web Wheeler extraordinair
    The only way to make a Jeep do what you want is to cut that bitch.
    www.krawldaddyoffroad.com
    Super JK Freak jsears's Avatar
    Portland, OR
    You'll probably rub on the 37's as well. I have 37x12.50x17's with 4.5" of backspacing and it rubs.
    2007 Jeep Wrangler Unlimited | RK 5.5" | Synergy Long Arms | D60/14B | 17'' Trail Ready Beadlocks | 37" Goodyear MTR/K | LoD Shorty Signature Series Rear Bumper/Tire Carrier | LoD Shorty Signature Series Shorty with Stinger | Warn M8000 | ORW JK Transmission Cooler
    Supporting Freak Hook-em's Avatar
    You are going to have to add spacers (NOOOOOOOO!) or switch to something with a 3-3.5" backspacing like Spiderlocks or something similar.
    Senior JK Freak goodysgotacuda's Avatar
    Denton area, Texas
    Quote Originally Posted by Hook-em View Post
    You are going to have to add spacers (NOOOOOOOO!).
    ? I've got 54,000 miles on spacers. Wouldn't hesitate recommending them.
    '09 2dr Rubicon - 6spd | 37s | 4.88s | DIY PSC Ram | OR-Fab cage | Poly Cage | BFH Front | XRC Rear | XRC12 Winch | Walker Evan's Beadlocks | + other stuff
    FaceBook.com/GoodyOffRoad
    Build Thread
    Portland, OR
    40k on my spacers. Never an issue.
    I have no problems running spacers. I would run a 1.5" spacers with the 37x12.5 as well with a 4.5" bs wheel. You may not rub while on the road but if you are deflated and pushing on the tire you may run into problems. I popped a 37" mtr/k with 4.5" bs wheel and 5" of lift on a tough climb once when it got into the tied up sway bar. What tire are you looking at? I would agree with not wanting to run an E rated tire, I really prefer the C
    Northern Virginia
    Thanks all. I've got no problem with spacers from a functional standpoint, I think they are a maintanence item, check 'me, keep 'em tight and all is good. My hesitation in this application is extending the distance of the mass from the bearing points. Ie the tire from the c and the ball joints. I keep thinking of it like putting a pipe on a wrench...a little extra length can make a huge impact on the forces generated. The tires I'm looking at are Toyo Open Country @ 93-100 lbs. if I were looking at a 75-80lb tire I don't think I'd be so concerned. Again thanks for any input.
    Senior JK Freak Danny4652's Avatar
    Williamsport, MD
    Quote Originally Posted by TheDirtman View Post
    Just for my clarification....
    Did you run into these problems even with 1.5 inch spacers and a 4.5 bs wheel?
    2010 JKU / MetalCloak 2.5 Springs/ Fox 2.0 Shox / Truss, Gussets, Front LCA Skids by River Raider O.R. / MetalCloak Upper/Lower CA's Front & Rear / Track Bar/ 37 x 12.50 x 17 Nitto Trail Grappler's on Pro Comp 7031ís / 5:13 Yukon Gears / PSC Diff Covers, Body Armor, & Evap. Skid, Hard Top / ORH Fastback Soft Top / Bushwacker Flat Fenders / PSC Rocker Knockers / EVO Protek Full Skid System / EVO Rock Stars / Nemisis Front Shock Relocation Brackets
    METALCLOAK
    NORTHRIDGE 4X4
    The tire puncture was without spacers. On the road inflated I did not have any rubbing without the spacers but pushing on the tires in twisted up off road situations was a different story.
