Results 1 to 10 of 11
    Winching Angles Information
    Here's some good info I found.. I found it educational
    Next to the winch itself, the most important item to have on board is a pulley block. Pulley blocks can be used for doubling the power of your winch, and can be used for self recovery, direct pulling, and indirect pulling. All are shown in the following illustrations.
    The anchor point (when used) must be a secure one such as a tree, another vehicle or other firm object. For direct vehicle recovery, attach the pulley block to the anchor point and then feed the wire rope out from the winch, through the block and back to an appropriate point of attachment on the vehicle such as a tow hook or the frame of the vehicle. This will effectively double your pulling capacity and greatly reduce the effort of the winch to get your vehicle recovered.
    Direct load pulling of load (or other vehicle) using your vehicle as the anchor point and attaching the pulley block to the load
    Indirect pulling may be required because of obstacles or impassable surfaces. The pulley block is attached to the load and the wire rope is attached to an anchor point offset from the direction in which the load is to be moved. Note that this procedure is not recommended unless necessary as winch pulling power and line speed will decrease as angle between the wire ropes increases.
    Using a single-line winch capacity of 2000lbs., the capacity of the winch is effectively doubled using the double-line methods shown. Winch capacity in figure above remains at 2000lbs. as this is still a single line application.
    NEVER attach the winch cable back onto itself as shown below. Use of a nylon sling and shackle is strongly recommended to avoid damaging you wire rope and the tree
    It is good practice to use a heavy blanket or jacket over the wire rope. If a rope failure should occur the weight of the cloth will act as a damper and help prevent the broken rope from whipping. A raised vehicle hood will also give some protection should the rope break. Also, the blanket acts as a visual warning to bystanders and is likely to prevent them from walking into or tripping over the wire rope.
    You should always make sure that everyone keeps well back and away from any winching activity. However, in the case of a long distance pull you may not see a person who inadvertently walks towards the wire rope, such a cover will help bring the wire rope to their attention, as well as bringing it to the ground if there is a rope/cable failure. It is recommended that in such circumstances two operators should be in attendance.
    Senior JK Freak Jae suite's Avatar
    Ct
    Quote Originally Posted by ECHO View Post
    great info echo
    Senior JK Freak jbsmith44's Avatar
    Florence SC
    Ya I agree great info to take in
    Senior JK Freak Revyjku08's Avatar
    Vancouver Island
    Great info....STICKY!!!
    "Jeep Modifications are like wiping your ass with a hula-hoop.....it's never ending!"
    Super JK Freak DeReK_AgIn's Avatar
    Norfolk VA
    thats good info
    Senior JK Freak JPchick's Avatar
    Regina, SK
    Did you happen to have any pictures for noobs like me?
    Hello, I am Kelsey.
    2007 Bright Silver Rubicon Watch me grow here!
    Freak For Life Navyvetnorwich91's Avatar
    Bradenton, Florida
    Just found this post from the other day. Craig, thanks for putting it up. I was always a bit confused on the pulley blocks but the diagrams are really helpful. Thanks again.
    Dave
    My rig, his name is Brett.
    He's an '11 4dr black Rubi w/ 37 Toyos
    Teraflex / Poison Spyder / GenRight / RCVs front & rear / ProRock / Superwinch / Rigid / AEV / Metal Cloak
    Hey not problem, I have yet you use my block.. my winch has gotten me & my friends out of trouble so far.. but; it's very good insurance to have if you need a weird angle or to double your pulling strength... I have watched a youtube of a guy in Austrailia that used a winch extension line and 5 snatch blocks and pulled himself out backwards..
    Senior JK Freak Kevlarjk's Avatar
    Lillington nc
    Here is a pic of a nice little recovery we had going on this past summer at Uwharrie in nc. Tree saver and snatch block connected to frame underneath the driver door back the the winching jeep. The one from the front pulling the flipped one forward at the same time The whole point of pulling it forward was once we got it up right the back drivers tire would still be on the ledge so we decided the doe this to get it off the ledge at the same time. He backed up the ledge and that's what made him flip in the first place.
    Attached Thumbnails Attached Thumbnails ImageUploadedByTapatalk1325967605.863110.jpg
    Post up a bigger picture please
