Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    Milano, Italy
    Wrangler JK '07-UP Error Codes
    (It would be also nice to find out how to erase an Error Code from memory after have solved the problem that was triggering it)
    To check your JK Codes, use this sequence on your ignition. Insert key and turn the ignition On-Off-On-Off then back to the On position and then notice the codes given in the odometer read-out.
    B1402 - FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1403 - FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1405 - FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1406 - FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1407 - FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1409 - REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B140A - REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B140B - REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B140D - REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B140E - REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B140F - REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1420 - AUDIO CASSETTE ERROR/INOPERABLE CASSETTE
    B1421 - AUDIO CD READ ERROR/INOPERABLE DISC
    B1422 - AUDIO DVD READ ERROR/INOPERABLE DISC
    B1423 - VES DVD READ ERROR/INOPERABLE DISC
    B1424 - IMPROPER DVD-WRONG REGION
    B1429 - RADIO DISPLAY HIGH TEMPERATURE
    B142A - RADIO UNIT HIGH TEMPERATURE
    B142C - VES VIDEO SCREEN DISCONNECTED
    B142D - AUDIO ANTENNA NOT CONNECTED
    B142E - GPS ANTENNA NOT CONNECTED
    B142F - SATELLITE RADIO ANTENNA NOT CONNECTED
    B1430 - SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE
    B1460 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B1461 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1462 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1463 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1464 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B1465 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B1466 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1467 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1468 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1469 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B146A - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B146B - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B146C - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B146D - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B146E - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B146F - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B1470 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1471 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1472 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1473 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B1474 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B1475 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1476 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1477 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1478 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B1479 - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B147A - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B147B - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B147C - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B147D - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B1613 - PANEL ILLUMINATION CONTROL CIRCUIT LOW
    B1615 - PANEL ILLUMINATION CONTROL CIRCUIT OPEN
    B161A - COURTESY/DOME LAMP CONTROL CIRCUIT
    B161E - READING LAMP CONTROL CIRCUIT
    B162B - LEFT LOW BEAM CONTROL CIRCUIT LOW
    B162C - LT LOW BEAM CONTROL CKT HI
    B162F - RIGHT LOW BEAM CONTROL CIRCUIT LOW
    B1630 - RIGHT LOW BEAM CONTROL CIRCUIT HIGH
    B1633 - LEFT HI BEAM CONTROL CIRCUIT LOW
    B1634 - LEFT HI BEAM CONTROL CIRCUIT HIGH
    B1637 - RIGHT HI BEAM CONTROL CIRCUIT LOW
    B1638 - RIGHT HI BEAM CONTROL CIRCUIT HIGH
    B163B - FRONT LEFT TURN CONTROL CIRCUIT LOW
    B163C - FRONT LEFT TURN CONTROL CIRCUIT HIGH
    B163F - FRONT RIGHT TURN CONTROL CIRCUIT LOW
    B1640 - FRONT RIGHT TURN CONTROL CIRCUIT HIGH
    B1643 - REAR LEFT TURN CONTROL CIRCUIT LOW
    B1644 - REAR LEFT TURN CONTROL CIRCUIT HIGH
    B1644 - RIGHT STOP LAMP CONTROL CIRCUIT HIGH
    B1647 - REAR RIGHT TURN CONTROL CIRCUIT LOW
    B1648 - REAR RIGHT TURN CONTROL CIRCUIT HIGH
    B1663 - REAR FOG LAMP CONTROL CIRCUIT LOW
    B1664 - REAR FOG LAMP CONTROL CIRCUIT HIGH
    B166B - LEFT TRAILER TOW LAMP CONTROL CIRCUIT LOW
    B166C - LEFT TRAILER TOW LAMP CONTROL CIRCUIT HIGH
    B166F - RIGHT TRAILER TOW LAMP CONTROL CIRCUIT LOW
    B1670 - RIGHT TRAILER TOW LAMP CONTROL CIRCUIT HIGH
    B16B1 - LEFT STOP LAMP CONTROL CIRCUIT HIGH
    B16F8 - FRONT LEFT FOG LAMP CONTROL CIRCUIT LOW
    B16F9 - FRONT LEFT FOG LAMP CONTROL CIRCUIT HIGH
    B16FC - FRONT RIGHT FOG LAMP CONTROL CIRCUIT LOW
    B16FD - FRONT RIGHT FOG LAMP CONTROL CIRCUIT HIGH
    B17B8 - LEFT STOP LAMP CONTROL CIRCUIT OVERCURRENT
    B17B9 - RIGHT STOP LAMP CONTROL CIRCUIT OVERCURRENT
    B17BA - HEADLAMP LEVELING MOTOR CONTROL CIRCUIT OVERCURRENT
    B17BF - LEFT SIDEMARKER LAMP CONTROL CIRCUIT OVERCURRENT
    B17C4 - RIGHT SIDEMARKER LAMP CONTROL CIRCUIT OVERCURRENT
    B1801 - DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW - CLUSTER
    B1806 - PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW - TIPM
    B1934 - DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK - CLUSTER
    B1935 - PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK - TIPM
    B1A08 - RKE FOB 1 PERFORMANCE
    B1A09 - RKE FOB 2 PERFORMANCE
    B1A0A - RKE FOB 3 PERFORMANCE
    B1A0B - RKE FOB 4 PERFORMANCE
    B1A0C - RKE FOB 5 PERFORMANCE
    B1A0D - RKE FOB 6 PERFORMANCE
    B1A0E - RKE FOB 7 PERFORMANCE
    B1A0F - RKE FOB 8 PERFORMANCE
    B1A10 - RKE FOB 1 BATTERY LOW
    B1A11 - RKE FOB 2 BATTERY LOW
    B1A12 - RKE FOB 3 BATTERY LOW
    B1A13 - RKE FOB 4 BATTERY LOW
    B1A14 - RKE FOB 5 BATTERY LOW
    B1A15 - RKE FOB 6 BATTERY LOW
    B1A16 - RKE FOB 7 BATTERY LOW
    B1A17 - RKE FOB 8 BATTERY LOW
    B1A20 - PRE-ARM TIMEOUT
    B1A23 - RKE RECEIVER PERFORMANCE
    B1A24 - KEY NOT PROGRAMMED
    B1A25 - INVALID KEY
    B1A26 - MAXIMUM NUMBER OF KEYS PROGRAMMED
    B1A27 - SKREEM PROGRAMMING PERFORMANCE
    B1A28 - ECM MISMATCH WITH SKIM
    B1A29 - SKIM BASESTATION MISMATCH
    B1A3C - INTERNAL SIREN BATTERY
    B1A3D - SIREN BATTERY / LOSS OF POWER SUPPLY
    B1A3E - SIREN/ITM MISMATCH
    B1A3F - ITM ARMING SEQUENCE PERFORMANCE
    B1A48 - INTRUSION SENSOR 1 INTERNAL
    B1A5F - INTRUSION SENSOR 2 INTERNAL
    B1A6D - INTRUSION SENSOR 3 INTERNAL
    B1B00 - DRIVER AIRBAG SQUIB 1 CIRCUIT LOW
    B1B01 - DRIVER AIRBAG SQUIB 1 CIRCUIT HIGH
    B1B02 - DRIVER AIRBAG SQUIB 1 CIRCUIT OPEN
    B1B03 - DRIVER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER
    B1B04 - DRIVER AIRBAG SQUIB 2 CIRCUIT LOW
    B1B05 - DRIVER AIRBAG SQUIB 2 CIRCUIT HIGH
    B1B06 - DRIVER AIRBAG SQUIB 2 CIRCUIT OPEN
    B1B07 - DRIVER AIRBAG SQUIB 2 CIRCUIT SHORTED TOGETHER
    B1B08 - PASSENGER AIRBAG SQUIB 1 CIRCUIT LOW
    B1B09 - PASSENGER AIRBAG SQUIB 1 CIRCUIT HIGH
    B1B0A - PASSENGER AIRBAG SQUIB 1 CIRCUIT OPEN
    B1B0B - PASSENGER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER
    B1B0C - PASSENGER AIRBAG SQUIB 2 CIRCUIT LOW
    B1B0D - PASSENGER AIRBAG SQUIB 2 CIRCUIT HIGH
    B1B0E - PASSENGER AIRBAG SQUIB 2 CIRCUIT OPEN
    B1B0F - PASSENGER AIRBAG SQUIB 2 CIRCUITS SHORTED TOGETHER
    B1B54 - 1ST ROW PASSENGER SEAT BELT SENSOR CIRCUIT LOW
    B1B55 - 1 ST ROW PASSENGER SEAT BELT SENSOR CIRCUIT HIGH
    B1B56 - 1 ST ROW PASSENGER SEAT BELT SENSOR CIRCUIT OPEN
    B1B70 - UP-FRONT LEFT SATELLITE ACCELERATION SENSOR INTERNAL
    B1B71 - UP-FRONT RIGHT SATELLITE ACCELERATION SENSOR INTERNAL
    B1B72 - LEFT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL
    B1B75 - RIGHT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL
    B1B78 - PASSENGER SEAT WEIGHT SENSOR 3 - LEFT FRONT PERFORMANCE
    B1B79 - PASSENGER SEAT WEIGHT SENSOR 3 - LEFT FRONT INPUT CIRCUIT LOW
    B1B7A - PASSENGER SEAT WEIGHT SENSOR 3 - LEFT FRONT INPUT CIRCUIT HIGH
    B1B7D - PASSENGER SEAT WEIGHT SENSOR 2 - RIGHT FRONT PERFORMANCE
    B1B7E - PASSENGER SEAT WEIGHT SENSOR 2 - RIGHT FRONT INPUT CIRCUIT LOW
    B1B7F - PASSENGER SEAT WEIGHT SENSOR 2 - RIGHT FRONT INPUT CIRCUIT HIGH
    B1B82 - PASSENGER SEAT WEIGHT SENSOR 4 - LEFT REAR PERFORMANCE
    B1B83 - PASSENGER SEAT WEIGHT SENSOR 4 - LEFT REAR INPUT CIRCUIT LOW
    B1B84 - PASSENGER SEAT WEIGHT SENSOR 4 - LEFT REAR INPUT CIRCUIT HIGH
    B1B87 - PASSENGER SEAT WEIGHT SENSOR 1 - RIGHT REAR PERFORMANCE
    B1B88 - PASSENGER SEAT WEIGHT SENSOR 1 - RIGHT REAR INPUT CIRCUIT LOW
    B1B89 - PASSENGER SEAT WEIGHT SENSOR 1 - RIGHT REAR INPUT CIRCUIT HIGH
    B1B8D - DRIVER SEAT TRACK POSITION SENSOR CIRCUIT LOW
    B1B8E - DRIVER SEAT TRACK POSITION SENSOR CIRCUIT HIGH
    B1B8F - DRIVER SEAT TRACK POSITION SENSOR CIRCUIT OPEN
    B1B93 - PASSENGER SEAT TRACK POSITION SENSOR CIRCUIT LOW
    B1B94 - PASSENGER SEAT TRACK POSITION SENSOR CIRCUIT HIGH
    B1B95 - PASSENGER SEAT TRACK POSITION SENSOR CIRCUIT OPEN
    B1BA5 - AIRBAG SQUIB CONFIGURATION MISMATCH
    B1BA6 - OCCUPANT CLASSIFICATION UNDETERMINED
    B1BA7 - OCCUPANT CLASSIFICATION SYSTEM VERIFICATION REQUIRED
    B1BA8 - OCM SYSTEM OUT OF CALIBRATION/NOT CALIBRATED
    B1BAA - OCCUPANT CLASSIFICATION MODULE CONFIGURATION MISMATCH
    B1BBA - PASSENGER SEAT WEIGHT SENSOR SUPPLY CIRCUIT
    B1BBB - PASSENGER SEAT WEIGHT SENSOR INPUTS SHORTED TOGETHER
    B1BBC - OCS NEGATIVE SYSTEM WEIGHT
    B1BBD - OCM CURRENT CONFIGURATION TABLE UNPROGRAMMED
    B1BC7 - DEPLOYMENT DATA RECORD FULL
    B1C27 - LEFT SIDE SEAT THORAX SQUIB 1 LOW
    B1C28 - LEFT SIDE SEAT THORAX SQUIB 1 HIGH
    B1C29 - LEFT SIDE SEAT THORAX SQUIB 1 OPEN
    B1C2A - LEFT SIDE SEAT THORAX SQUIB 1 SHORTED TOGETHER
    B1C2B - RIGHT SIDE SEAT THORAX SQUIB 1 LOW
    B1C2C - RIGHT SIDE SEAT THORAX SQUIB 1 HIGH
    B1C2D - RIGHT SIDE SEAT THORAX SQUIB 1 OPEN
    B1C2E - RIGHT SIDE SEAT THORAX SQUIB 1 SHORTED TOGETHER
    B1C38 - 1ST ROW DRIVER RETRACTOR PRETENSIONER CIRCUIT LOW
    B1C39 - 1ST ROW DRIVER RETRACTOR PRETENSIONER CIRCUIT HIGH
    B1C3A - 1ST ROW DRIVER RETRACTOR PRETENSIONER CIRCUIT OPEN
    B1C3B - 1ST ROW DRIVER RETRACTOR PRETENSIONER CIRCUIT SHORTED TOGETHER
    B1C47 - 1ST ROW PASSENGER RETRACTOR PRETENSIONER CIRCUIT LOW
    B1C48 - 1ST ROW PASSENGER RETRACTOR PRETENSIONER CIRCUIT HIGH
    B1C49 - 1ST ROW PASSENGER RETRACTOR PRETENSIONER CIRCUIT OPEN
    B1C4A - 1ST ROW PASSENGER RETRACTOR PRETENSIONER CIRCUIT SHORTED TOGETHER
    B2101 - IGNITION RUN/START INPUT CIRCUIT LOW
    B2102 - IGNITION RUN/START INPUT CIRCUIT HIGH
    B210A - SYSTEM VOLTAGE LOW (WCM)
    B210B - SYSTEM VOLTAGE HIGH (WCM)
    B210D - BATTERY VOLTAGE LOW (WCM)
    B210E - BATTERY VOLTAGE HIGH (WCM)
    B212C - IGNITION RUN/START INPUT CIRCUIT OPEN
    B212D - IGNITION RUN ONLY INPUT CIRCUIT OPEN
    B2142 - IGNITION OFF DRAW (IOD) FUSE NOT PRESENT
    B219A - IGNITION UNLOCK RUN/START CONTROL CIRCUIT OVERCURRENT
    B219F - IGNITION OFF DRAW (IOD) FUSE BLOWN
    B2201 - CALIBRATION MISMATCH
    B2204 - ECU CONFIGURATION MISMATCH
    B2205 - ORIGINAL VIN MISSING/MISMATCH
    B2206 - CURRENT VIN MISSING/MISMATCH
    B2206 - CURRENT VIN MISSING / MISMATCH
    B2207 - OCCUPANT RESTRAINT CONTROLLER INTERNAL 1
    B2208 - OCCUPANT RESTRAINT CONTROLLER INTERNAL 2
    B2209 - OCCUPANT RESTRAINT CONTROLLER INTERNAL 3
    B220A - OCCUPANT RESTRAINT CONTROLLER INTERNAL 4
    B220B - OCCUPANT RESTRAINT CONTROLLER FIRING STORED ENERGY
    B220C - OCCUPANT RESTRAINT CONTROLLER ACCELEROMETER 1 INTERNAL
    B220D - OCCUPANT RESTRAINT CONTROLLER ACCELEROMETER 2 INTERNAL
    B2212 - OCCUPANT CLASSIFICATION MODULE INTERNAL
    B2222 - SATELLITE RADIO RECEIVER INTERNAL
    B2224 - SKREEM INTERNAL
    B2229 - SKREEM INTERNAL - SKIM IMMOBILIZER
    B222A - VEHICLE LINE MISMATCH
    B222C - VEHICLE CONFIGURATION NOT PROGRAMMED
    B223B - VEHICLE CONFIGURATION MISMATCH
    B223C - INTRUSION TRANSCEIVER MODULE INTERNAL
    B223D - OCCUPANT CLASSIFICATION MODULE DTC PRESENT
    B2254 - COLUMN LOCK MODULE INTERNAL
    B2304 - WIPER PARK SWITCH INPUT CIRCUIT LOW
    B2305 - WIPER PARK SWITCH INPUT CIRCUIT HIGH
    B230D - REAR WIPER PARK SWITCH INPUT CIRCUIT LOW (STUCK LOW)
    B230E - REAR WIPER PARK SWITCH INPUT CIRCUIT HIGH (STUCK HIGH)
    B2323 - HEADLAMP WASHER MOTOR CONTROL CIRCUIT LOW
    B2324 - HEADLAMP WASHER MOTOR CONTROL CIRCUIT HIGH
    B2339 - HORN SWITCH STUCK
    C0077 - LOW TIRE PRESSURE
    C1404 - TRANSFER CASE RANGE POSITION SENSOR CIRCUIT LOW (TIPM)
    C1405 - TRANSFER CASE RANGE POSITION SENSOR CIRCUIT HIGH (TIPM)
    C1417 - FRONT DIFFERENTIAL CONTROL CIRCUIT LOW
    C1418 - FRONT DIFFERENTIAL CONTROL CIRCUIT HIGH
    C141D - REAR DIFFERENTIAL CONTROL CIRCUIT LOW
    C141E - REAR DIFFERENTIAL CONTROL CIRCUIT HIGH
    C1501 - TIRE PRESSURE SENSOR 1 INTERNAL
    C1502 - TIRE PRESSURE SENSOR 2 INTERNAL
    C1503 - TIRE PRESSURE SENSOR 3 INTERNAL
    C1504 - TIRE PRESSURE SENSOR 4 INTERNAL
    C2100 - BATTERY VOLTAGE LOW
    C2101 - BATTERY VOLTAGE HIGH
    C2207 - OFF ROAD ECU INTERNAL
    P0016 - Crankshaft/camshaft Timing Misalignment
    P0031 - O2 Sensor 1/1 Heater Circuit Low
    P0032 - O2 Sensor 1/1 Heater Circuit High
    P0037 - O2 Sensor 1/2 Heater Circuit Low
    P0038 - O2 Sensor 1/2 Heater Circuit High
    P0051 - O2 Sensor 2/1 Heater Circuit Low
    P0052 - O2 Sensor 2/1 Heater Circuit High
    P0057 - O2 Sensor 2/2 Heater Circuit Low
    P0058 - O2 Sensor 2/2 Heater Circuit High
    P0071 - Ambient Air Temperature Sensor Performance
    P0072 - Ambient Air Temperature Sensor Circuit Low
    P0073 - Ambient Air Temperature Sensor Circuit High
    P0107 - Manifold Absolute Pressure Sensor Circuit Low
    P0108 - Manifold Absolute Pressure Sensor Circuit High
    P0111 - Intake Air Temperature Sensor Rationality
    P0112 - Intake Air Temperature Sensor Circuit Low
    P0113 - Intake Air Temperature Sensor Circuit High
    P0116 - Engine Coolant Temperature Sensor Performance
    P0117 - Engine Coolant Temperature Sensor Circuit Low
    P0118 - Engine Coolant Temperature Sensor Circuit High
    P0121 - Throttle Position Sensor 1 Performance
    P0122 - Tps/apps Circuit Low
    P0122 - Throttle Position Sensor 1 Circuit Low
    P0123 - Tps/app Circuit High
    P0123 - Throttle Position Sensor 1 Circuit High
    P0124 - Tps/app Intermittent
    P0125 - Insufficient Coolant Temperature For Closed-loop Fuel Control
    P0128 - Thermostat Rationality
    P0129 - Barometric Pressure Out-of-range Low
    P0131 - O2 Sensor 1/1 Circuit Low
    P0132 - O2 Sensor 1/1 Circuit High
    P0133 - O2 Sensor 1/1 Slow Response
    P0135 - O2 Sensor 1/1 Heater Performance
    P0137 - O2 Sensor 1/2 Circuit Low
    P0138 - O2 Sensor 1/2 Circuit High
    P0139 - O2 Sensor 1/2 Slow Response
    P013a - O2 Sensor 1/2 Slow Response - Rich To Lean
    P013c - O2 Sensor 2/2 Slow Response - Rich To Lean
    P0141 - O2 Sensor 1/2 Heater Performance
    P0151 - O2 Sensor 2/1 Circuit Low
    P0152 - O2 Sensor 2/1 Circuit High
    P0153 - O2 Sensor 2/1 Slow Response
    P0155 - O2 Sensor 2/1 Heater Performance
    P0157 - O2 Sensor 2/2 Circuit Low
    P0158 - O2 Sensor 2/2 Circuit High
    P0159 - O2 Sensor 2/2 Slow Response
    P0161 - O2 Sensor 2/2 Heater Performance
    P0171 - Fuel System 1/1 Lean
    P0172 - Fuel System 1/1 Rich
    P0174 - Fuel System 2/1 Lean
    P0175 - Fuel System 2/1 Rich
    P0201 - Fuel Injector 1 Circuit
    P0202 - Fuel Injector 2 Circuit
    P0203 - Fuel Injector 3 Circuit
    P0204 - Fuel Injector 4 Circuit
    P0205 - Fuel Injector 5 Circuit
    P0206 - Fuel Injector 6 Circuit
    P0218 - High Temperature Operation Activated
    P0221 - Throttle Position Sensor 2 Performance
    P0222 - Throttle Position Sensor 2 Circuit Low
    P0223 - Throttle Position Sensor 2 Circuit High
    P0300 - Multiple Cylinder Misfire
    P0301 - Cylinder 1 Misfire
    P0302 - Cylinder 2 Misfire
    P0303 - Cylinder 3 Misfire
    P0304 - Cylinder 4 Misfire
    P0305 - Cylinder 5 Misfire
    P0306 - Cylinder 6 Misfire
    P0315 - No Crank Sensor Learned
    P0325 - Knock Sensor 1 Circuit
    P0335 - Crankshaft Position Sensor Circuit
    P0339 - Crankshaft Position Sensor Intermittent
    P0340 - Camshaft Position Sensor Circuit
    P0344 - Camshaft Position Sensor Intermittent
    P0401 - Egr System Performance
    P0403 - Egr Solenoid Circuit
    P0404 - Egr Position Sensor Rationality Open
    P0405 - Egr Position Sensor Circuit Low
    P0406 - Egr Position Sensor Circuit High
    P0420 - Catalyst Efficiency (bank 1)
    P0430 - Catalyst Efficiency (bank 2)
    P0440 - General Evap System Failure
    P0441 - Evap Purge System Performance
    P0443 - Evap Purge Solenoid Circuit
    P0452 - Evap Pressure Switch Stuck Closed
    P0455 - Evap Purge System Large Leak
    P0456 - Evap Purge System Small Leak
    P0457 - Loose Fuel Cap
    P0461 - Fuel Level Sensor 1 Performance
    P0462 - Fuel Level Sensor 1 Circuit Low
    P0463 - Fuel Level Sensor 1 Circuit High
    P0480 - Cooling Fan 1 Control Circuit
    P0481 - Cooling Fan 2 Control Circuit
    P0501 - Vehicle Speed Sensor 1 Performance
    P0503 - Vehicle Speed Sensor 1 Erratic
    P0506 - Idle Speed Performance Lower Than Expected
    P0507 - Idle Speed Performance Higher Than Expected
    P050b - Cold Start Ignition Timing Performance
    P050d - Cold Start Rough Idle
    P0513 - Invalid Skim Key
    P0522 - Engine Oil Pressure Too Low
    P0532 - A/c Pressure Sensor Circuit Low
    P0533 - A/c Pressure Sensor Circuit High
    P0562 - Battery Voltage Low
    P0563 - Battery Voltage High
    P0571 - Brake Switch 1 Performance
    P0572 - Brake Switch 1 Stuck On
    P0573 - Brake Switch 1 Stuck Off
    P0579 - Speed Control Switch 1 Performance
    P0580 - Speed Control Switch 1 Circuit Low
    P0581 - Speed Control Switch 1 Circuit High
    P0585 - Speed Control Switch 1/2 Correlation
    P0591 - Speed Control Switch 2 Performance
    P0592 - Speed Control Switch 2 Circuit Low
    P0593 - Speed Control Switch 2 Circuit High
    P0600 - Serial Communication Link
    P0601 - Internal Memory Checksum Invalid
    P0602 - Control Module Programming Error/not Programmed
    P0604 - Internal Control Module Ram
    P0605 - Internal Control Module Rom
    P0606 - Internal Ecm Processor
    P060b - Etc A/d Ground Performance
    P060d - Etc Level 2 App Performance
    P060e - Etc Level 2 Tps Performance
    P060f - Etc Level 2 Ect Performance
    P0613 - Internal Transmission Processor
    P061a - Etc Level 2 Torque Performance
    P061c - Etc Level 2 Rpm Performance
    P0622 - Generator Field Control Circuit
    P0627 - Fuel Pump Control Circuit
    P062c - Etc Level 2 Mph Performance
    P0630 - Vin Not Programmed In Pcm
    P0632 - Odometer Not Programmed In Pcm
    P0633 - Skim Secret Key Not Stored In Pcm
    P063a - Generator Voltage Sense Circuit
    P0642 - Sensor Reference Voltage 1 Circuit Low
    P0643 - Sensor Reference Voltage 1 Circuit High
    P0645 - A/c Clutch Control Circuit
    P0652 - Sensor Reference Voltage 2 Circuit Low
    P0653 - Sensor Reference Voltage 2 Circuit High
    P0685 - Auto Shutdown Control Circuit
    P0688 - Auto Shutdown Sense Circuit Low
    P0691 - Cooling Fan 1 Control Circuit Low
    P0692 - Cooling Fan 1 Control Circuit High
    P0693 - Cooling Fan 2 Control Circuit Low
    P0694 - Cooling Fan 2 Control Circuit High
    P0700 - Transmission Control System (mil Request)
    P0703 - Brake Switch 2 Performance
    P0706 - Transmission Range Sensor Rationality
    P0711 - Transmission Temperature Sensor Performance
    P0712 - Transmission Temperature Sensor Low
    P0713 - Transmission Temperature Sensor High
    P0714 - Transmission Temperature Sensor Intermittent
    P0716 - Input Speed Sensor 1 Circuit Performance
    P0721 - Output Speed Sensor Circuit Performance
    P0726 - Engine Speed Input Circuit Range/performance
    P0731 - Gear Ratio Error In 1st
    P0732 - Gear Ratio Error In 2nd
    P0733 - Gear Ratio Error In 3rd
    P0734 - Gear Ratio Error In 4th
    P0736 - Gear Ratio Error In Reverse
    P0740 - Tcc Out Of Range
    P0750 - Lr Solenoid Circuit
    P0755 - 2/4 Solenoid Circuit
    P0760 - Od Solenoid Circuit
    P0765 - Ud Solenoid Circuit
    P0841 - Lr Pressure Switch Rationality
    P0845 - 2/4 Hydraulic Pressure Test
    P0846 - 2/4 Pressure Switch Rationality
    P0850 - Park/neutral Switch Performance
    P0853 - Overdrive/tow Switch Input Circuit Stuck
    P0868 - Line Pressure Low
    P0869 - Line Pressure High
    P0870 - Od Hydraulic Pressure Test
    P0871 - Od Pressure Switch Rationality
    P0882 - Tcm Power Input Low
    P0883 - Tcm Power Input High
    P0884 - Power Up At Speed
    P0888 - Transmission Relay Always Off
    P0890 - Switched Battery
    P0891 - Transmission Relay Always On
    P0897 - Transmission Fluid Deteriorated
    P0933 - Line Pressure Sensor Circuit Performance
    P0934 - Line Pressure Sensor Circuit Low
    P0935 - Line Pressure Sensor Circuit High
    P0944 - Loss Of Hydraulic Pump Prime
    P0992 - 2/4/od Hydraulic Pressure Test
    P1115 - General Temperature Rationality
    P1128 - Closed Loop Fueling Not Achieved - Bank 1
    P1129 - Closed Loop Fueling Not Achieved - Bank 2
    P1273 - A/c Clutch Control Circuit 2 High (tipm)
    P1275 - A/c Clutch Control Circuit 2 Overcurrent (tipm)
    P128b - Tcm Power Control Circuit 2 Low - Tipm
    P128c - Tcm Power Control Circuit 2 High - Tipm
    P128d - Tcm Power Control Circuit 2 Open - Tipm
    P128e - Tcm Power Control Circuit 2 Overcurrent - Tipm
    P129c - Inverter Control Circuit High (tipm)
    P129e - Inverter Control Circuit Overcurrent (tipm)
    P1404 - Egr Position Sensor Rationality Closed
    P1501 - Vehicle Speed Sensor 1/2 Correlation - Drive Wheels
    P1502 - Vehicle Speed Sensor 1/2 Correlation - Non Drive Wheels
    P1572 - Brake Pedal Stuck On
    P1573 - Brake Pedal Stuck Off
    P1593 - Speed Control Switch 1/2 Stuck
    P1602 - Pcm Not Programmed
    P1607 - Pcm Internal Shutdown Timer Rationality Too Slow
    P1618 - Sensor Reference Voltage 1 Circuit Erratic
    P1628 - Sensor Reference Voltage 2 Circuit Erratic
    P1684 - Battery Was Disconnected
    P1696 - Eeprom Memory Write Denied/invalid
    P1697 - Emr (sri) Mileage Not Stored
    P1713 - Restricted Manual Valve In T2 Range
    P1745 - Transmission Line Pressure Too High For Too Long
    P1775 - Solenoid Switch Valve Latched In Tcc Position
    P1776 - Solenoid Switch Valve Latched In Lr Position
    P1790 - Fault Immediately After Shift
    P1794 - Speed Sensor Ground Error
    P1797 - Manual Shift Overheat
    P1897 - Level 1 Rpm Bus Unlock
    P2072 - Electronic Throttle Control System - Ice Blockage
    P2096 - Downstream Fuel Trim System 1 Lean
    P2097 - Downstream Fuel Trim System 1 Rich
    P2098 - Downstream Fuel Trim System 2 Lean
    P2099 - Downstream Fuel Trim System 2 Rich
    P2100 - Electronic Throttle Control Motor Circuit
    P2101 - Electronic Throttle Control Motor Performance
    P2107 - Electronic Throttle Control Module Processor
    P2110 - Electronic Throttle Control - Forced Limited Rpm
    P2111 - Electronic Throttle Control - Unable To Close
    P2112 - Electronic Throttle Control - Unable To Open
    P2115 - Accelerator Pedal Position Sensor 1 Minimum Stop Performance
    P2116 - Accelerator Pedal Position Sensor 2 Minimum Stop Performance
    P2118 - Electronic Throttle Control Motor Current Performance
    P2122 - Accelerator Pedal Position Sensor 1 Circuit Low
    P2123 - Accelerator Pedal Position Sensor 1 Circuit High
    P2127 - Accelerator Pedal Position Sensor 2 Circuit Low
    P2128 - Accelerator Pedal Position Sensor 2 Circuit High
    P2135 - Throttle Position Sensor 1/2 Correlation
    P2138 - Accelerator Pedal Position Sensor 1/2 Correlation
    P2161 - Vehicle Speed Sensor 2 Erratic
    P2166 - Accelerator Pedal Position Sensor 1 Maximum Stop Performance
    P2167 - Accelerator Pedal Position Sensor 2 Maximum Stop Performance
    P2172 - High Airflow / Vacuum Leak Detected (instantaneous Accumulation)
    P2173 - High Airflow / Vacuum Leak Detected (slow Accumulation)
    P2174 - Low Airflow / Restriction Detected (instantaneous Accumulation)
    P2175 - Low Airflow / Restriction Detected (slow Accumulation)
    P2181 - Cooling System Performance
    P2271 - O2 Sensor 1/2 Signal Stuck Rich
    P2273 - O2 Sensor 2/2 Signal Stuck Rich
    P2299 - Brake Pedal Position / Accelerator Pedal Position Incompatible
    P2302 - Ignition Coil 1 Secondary Circuit- Insufficient Ionization
    P2305 - Ignition Coil 2 Secondary Circuit- Insufficient Ionization
    P2308 - Ignition Coil 3 Secondary Circuit- Insufficient Ionization
    P2503 - Charging System Output Low
    P2504 - Charging System Output High
    P2610 - Pcm Internal Shutdown Timer Rationality Too Fast
    U0001 - Can C Bus
    U0001 - Can C Bus
    U0001 - Can C Bus Circuit
    U0002 - Can C Bus Off Performance
    U0010 - Can Interior Bus
    U0011 - Can Interior Bus Off Performance
    U0019 - Can Interior Bus(+)/(-) Circuit
    U0020 - Can Interior Bus Off Performance
    U0100 - Lost Communication With Ecm/pcm
    U0101 - Lost Communication With Tcm
    U0114 - Lost Communication With Final Drive Control Module
    U0121 - Lost Communication With Abs
    U0121 - Lost Communication With Anti-lock Brake Module
    U0121 - Lost Communication With Anti-lock Brake System (abs) Control Module
    U0126 - Lost Communication With Sas - Can C (steering Angle Sensor)
    U0141 - Lost Communication With Fcm
    U0141 - Lost Communication With Front Control Module (tipm)
    U0146 - Lost Communication With Central Gateway
    U0151 - Lost Communication With Occupant Restraint Controller (orc)
    U0154 - Lost Communication With Occupant Classification Module
    U0155 - Lost Communication With Cluster/ccn
    U0155 - Lost Communication With Cluster/ccn (skreem)
    U0161 - Lost Communication With Compass Module
    U0164 - Lost Communication With Hvac Control Module
    U0167 - Lost Communication With Intrusion Transceiver Control Module
    U0168 - Lost Communication With Vehicle Security Control Module (skreem-wcm)
    U0168 - Lost Communication With Vehicle Security Control Module (skreem/wcm)
    U0170 - Lost Communication W/up-front Left Satellite Acceleration Sensor
    U0171 - Lost Communication W/up-front Right Satellite Acceleration Sensor
    U0172 - Lost Communication W/left Side Satellite Acceleration Sensor 1
    U0175 - Communication W/right Side Satellite Acceleration Sensor 1
    U0184 - Lost Communication With Radio
    U0186 - Lost Communication With Audio Amplifier
    U0193 - Lost Communication With Traffic Information Receiver Module
    U0195 - Lost Communication With Sdars
    U0197 - Lost Communication With Hands Free Phone Module
    U0197 - Lost Communication With Hands Free Module
    U0199 - Lost Communication With Drivers Door Module
    U0200 - Lost Communication With Passenger Door Module
    U0415 - Implausible Data Received From Abs
    U0447 - Implausible Data Received From Central
    U1008 - Lin 1 Bus
    U1008 - Lin 1 Bus
    U110a - Lost Communication With Scm
    U110c - Lost Fuel Level Message
    U110d - Lost Communication With Security Siren
    U110e - Lost Ambient Temperature Message
    U110f - Lost Fuel Volume Message
    U1110 - Lost Vehicle Speed Message
    U1113 - Lost A/c Pressure Message
    U1120 - Lost Wheel Distance Message
    U113b - Lost Communication With Switch Bank Module
    U1149 - Lost Communication With Multifunction
    U1159 - Lost Communication With Asbs
    U1169 - Lost Communication With Intrusion Sensor 1
    U1170 - Lost Communication With Intrusion Sensor 2
    U1179 - Lost Communication With Intrusion Sensor 3
    U1403 - Implausible Fuel Level Signal Received
    U1411 - Implausible Fuel Volume Signal Received
    U1412 - Implausible Vehicle Speed Signal Received
    U1414 - Implausible/missing Ecu Network Configuration Data
    U1415 - Implausible/missing Vehicle Configuration Data
    U1416 - Implausible Security Siren Signal Received
    U1417 - Implausible Left Wheel Distance Signal Received
    U1418 - Implausible Right Wheel Distance Signal
    U1419 - Implausible Data Received From Ocs Sensor 3 - Left Front
    U141a - Implausible Data Received From Ocs Sensor 2 - Right Front
    U141b - Implausible Data Received From Ocs Sensor 4 - Left Rear
    U141c - Implausible Data Received From Ocs Sensor 1 - Right Rear
  2. #22
    MallCrawler Unowho007's Avatar
    London, Ontario, Canada
    Now just waiting to see if someone can disable the lockers so they can be used in 4 hi as well. I have a 2013 Rubicon, and I think this would be great.
  3. #23
    MallCrawler Pinzguy's Avatar
    New Mexico
    To use the lockers in 4hi as well, put into 4lo, lock em up, and return to 4 hi
  4. #24
    JK Freak
    Wading River
    pinzguy, you sure that actually works?
  5. #25
    New Mexico
    Not 100% but I'm not anywhere near my jeep to check it, and won't be for another 2 weeks. If you could do me a favor and check it, then tell the world what you found I'd appreciate it!
    Thanks
    Brady
    KCCO!
  6. #26
    JK Freak
    Wading River
    just because the lights stay on, doesn't mean the lockers are activated. I'm not going to be able to test for a while, but you've got me interested. Definitely if I can lock the rear and keep it locked in 4hi
  7. #27
    New Mexico
    Yeah I'm interested also
    Brady
    KCCO!
  8. #28
    Supporting Freak
    Michigan
    Is there a way to program the headlight flash with unlocking the doors to the OFF position. I am upgrading to Projector HIDs and dont want to prematurely shorten the bulb life.
    Mike- any ideas?
    Thanks
  9. #29
    Original Freak karls10jk's Avatar
    36 N
    I think there is a procedure for that in the manual......if only I could find my manual
    Sent from my DROID4 using Tapatalk
  10. #30
    36 N
    Quote Originally Posted by numb_crna View Post
    Mike- any ideas?
    Thanks
    Pg 23 in the manual says to press and hold (on your remote keyless entry fob) the Unlock for 4-10 seconds, after 4 seconds (continue to hold Unlock), press the Lock, then release both buttons and it should turn it off.
Tags for this Thread
