Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
  1. #11
    Senior JK Freak Res6cue's Avatar
    Owings Mills, MD
    Quote Originally Posted by Summertime Boss View Post
    This is a great thread and I'm glad you made it a sticky. Any word on disabling the horn when you lock the Jeep? I'm looking at adding a horn from a semi and the horn on lock has kept me from doing it so far. Also, how do you disable the light flash on lock and unlock?
    In your owners manual there are instructions on how to do this. For my '09 it was done by pushing a combination of buttons on the key. I would post the steps if I still had the owners manual.
    For my '12 & '13 it is done from the menu in the speedometer under Personal Settings. Use the buttons on the steering wheel to scroll the menu.
    Never Forget 343
    PTB-EGH
    '13 JKU Rubicon
    3" Teraflex Lift w/ 8 Flexarms, Rear Bumper, HD Tire Carrier & Diff Covers, LoD Stubby Stinger Front Bumper & Rock Sliders, JKS Quick Discos, Nitto Trail Grappler 37x12.5x17, LiquidMetals Gatlin Wheels, Engo 10,000# Synthetic Winch, Surprise Straps Grab Handles & SpiderWeb Shade - TFT edition
    '12 JK Artic "Yeti" - 2.5" Teraflex Lift, Nitto Trail Grappler 35x12.5x17, Poison Spyder Rocker Knockers, Surprise Straps Handles & Pink SpiderWeb Shade
  2. #12
    Supporting Freak Hook-em's Avatar
    I've got a 2009 and will look in my owners manual for this and pay it.
    Sent from the Matrix
  3. #13
    MD
    Subscribed
  4. #14
    As promised, here is the horn disable procedure for the alarm.
    If desired, the “Sound Horn On Lock” feature can be turned on or off using the following steps:
    1. Press the RKE transmitter LOCK button for 4 to 10 seconds.
    2. While the LOCK button is pressed (after four seconds), press the RKE transmitter PANIC button. Release both buttons.
    The “Sound Horn On Lock” feature can be reactivated by repeating this procedure.
    This is found on page 21 of the 2009 owner's manual. Also, the owner's manual can be downloaded for any year JK at the link provided below. Just select the year and the model from the drop down lists on the page and you will get a PDF version of the manual.
    JK Owner's Manual Link
  5. #15
    New JK Freak Summertime Boss's Avatar
    in my garage
    Quote Originally Posted by Res6cue View Post
    Never Forget 343
    PTB-EGH
    Quote Originally Posted by Hook-em View Post
    Thanks Res6cue and Hook-em. I will turn off the horn today. Now its time to get online and find that semi horn...
    2013 JKUR - BILLET SILVER METALLIC
    "You are what you do, not what you say you'll do." CGJ
  6. #16
    JK Freak DeepSeaJK's Avatar
    TN
    Bump! Great thread, thanks!
    /l ,[____],
    l---L -OlllllllO-
    ()_)-()_)-o-)_)
    DeepSea JK
  7. #17
    Chesterland. Ohio
    Will this work on the 2012 wrangler
    Lou
  8. #18
    Owings Mills, MD
    Not positive about the '12 but I am pretty sure that you can turn the horn off from the 'personal settings' located by pushing the button on your Speedometer. That is how I did it on my 2013.
    Never Forget 343
    PTB-EGH
    '13 JKU Rubicon
  9. #19
    I think all of these are in the manual. You can always look there for your model.
  10. #20
    New JK Freak Buddhacon's Avatar
    United States
    Quote Originally Posted by karls10jk View Post
    This is good info, I knew about the oil light. We missed the seat belt chime though.
    1) Turn the ignition on (do not start)
    2) Buckle and unbuckle the seat belt (driver's) 3 times within 10 seconds
    3) Turn off the ignition.
    Your seatbelt buzzer should be disabled, but you'll still get the light on the dash.
    Please remember to always use your seatbelt.
    Just did this hope it works on my 13
    Itching to climb, dig, and get dirty!
Tags for this Thread
