Page 42 of 42 FirstFirst ... 32404142
Results 411 to 413 of 413
  1. #411
    Pa
    Poison Spyder rear plate/light/camera/brake light holder
    So I installed the Poison Spyder rear JK tire carrier and well there was no real good way to mount a rear camera or a license plate light or third brake light. I spent hours searching different forums and didn't see a solution I really liked. So I decided to tackle this problem, and come up with a really good looking way to stay legal.
    I already had a Poison Spyder rear light and beat up tramp stamp. So I bought some clear plastic and black plastic and built this this weekend. I cut down the tramp stamp, sanded the back of clear plastic painted it black and Mango Tango so light could shine through it when brake light is on, when not it looks like the body color. I than tooled the back so it fits flush over exposed bolts, and had a place to run the wires. I ran the wires through the tube for a clean install, I also modified the hinge bracket so the wires went behind it. I think it came out pretty well.Click image for larger version.
ID:	58457Click image for larger version.
  2. #412
    MallCrawler icrashbikes's Avatar
    NJ
    I made a 3D printed rear camera/3rd brake light solution too.
    Designed the housing for two red LED modules and two cameras. One for backup, one for rearview that will output to a rearview mirror monitor. That tire is just way too big in the window.
    Printed opaque diffusers to try to get the light even instead of LED dots. Trial run here with cameras fitted and rigged to a motorcycle battery
    Fitted on the TF tire carrier
    And the backup cam in action. Ran this through a Lockpick so I have additional camera inputs and other goodies to play with
    I need to use a different camera for the rearview mirror replacement, the wide angle of the backup cam is essentially useless on the street. I also want to redesign the housing to stick out a little further so I can get the edge of the wheel out of view.
  3. #413
    VT
    Homemade Jurassic Park themed shift knob. Spared no expense.
    Instagram: jeepingthewild
