Page 64 of 65 FirstFirst ... 145462636465 LastLast
Results 631 to 640 of 646
  1. #631
    Freak For Life tslewisz's Avatar
    Bloomington, IL
    Looking good.
  2. #632
    Driving his wife's Jeep
    Ringer's Avatar
    Chardon, OH
    Looking good Tom. I like the new seats and cage additions.
    RubiXcon
    No matter what you have, there is ALWAYS a better way to do it.
    My build thread- http://www.jkfreaks.com/forums/showt...ld-up-of-JKarl
  3. #633
    Freak of Knowledge CJ7nvrstk's Avatar
    Prosper, TX
    Nice!
    11 JKU
    85 CJ-7
    RED Friday (Remember Everyone Deployed)
    My YouTube https://m.youtube.com/user/CJ7nvrstk
  4. #634
    Freaking JK Guru TheDirtman's Avatar
    Southwest Reno, NV
    Quote Originally Posted by TheDirtman View Post
    Finishing up the new sub frame cross members that hold all the control arm mounts at the frame. Now I can remove the transfer case and transmission if I need to without removing any control arms and I cleaned up the exhaust routing. I was able to get some more separation on the upper and lower links. I did loose about 1.5" of belly clearance but don't think it will be an issue.Attachment 56546Attachment 56547Attachment 56548
    Looking back now on this sub frame I should have built it with the front control arms farther back closer to where the front output shaft is on the transfer case for some better driveline angles and should have mounted the upper link mount to the right of the left exhaust. I could have gotten a little more separation in the links by putting it there as well.
  5. #635
    Southwest Reno, NV
    I was having some clearance issues with the shocks and the inner C at max articulation so I built a new front axle that is 72" WMS I also cut the front down and swapped out to a different radiator to get some additional up travel. Currently the front is limited to 8.5" of droop and has 7" of up travel from ride height. I need to swap out the drive line as it binds at this much droop.
  6. #636
    Ringer's Avatar
    Chardon, OH
    Looks great Tom. Need to get mine together so we can go wheeling again.
    RubiXcon
  7. #637
    Southwest Reno, NV
    Thanks. It feels like I got a decent amount of weight off the front but have not put it on the scales yet to see how much and I still have some aluminum fenders to build.Click image for larger version.
  8. #638
    Bloomington, IL
    Oh, man, that bumper and those flares have been on there a long time! Always great to see what you come up with.
    Sent from my P027 using Tapatalk
  9. #639
    Southwest Reno, NV
    Got the fronts done. Aluminum that weight in at 9 pounds each. 1.5"x.25" wall tube with 14 gauge skins.
  10. #640
    Bloomington, IL
    Those look great, Tom. Bet mine are lighter.
