Results 1 to 10 of 13
    SoCal
    Oil pressure problem
    I need some help! I'm getting the PO6DD code on my 3.6L which is the oil pressure code for the 2 stage oil pump. I can clear the code and go almost a day before it comes back and limits me to 3500 RPM or less. I have searched the internet and this site and need to see who has had this issue and the fix? I have purchased a MOPAR oil filter as suggested and the engine oil level is perfect. I'm reading it can be the filter, pressure sensor, the oil pump or the O ring on the oil pickup tube in the pan. I was thinking about doing the sensor first as it's the cheapest part although the labor is over $200 due to the location of the sensor under the intake! Poor design for a part that may need replaced at some point. If the sensor doesn't work then what? Any and all suggestions would be appreciated as I have a trip planned for Sedona in early January. Thank you
    Have you had someone with a good scanner do a diagnostic? The big boy scanners can give you better info. The O ring would be the cheapest route to go as you just drop the oil pan. The intake is not that big a deal to remove either but if you don't have the tools or skills then you are at the mercy of a shop and things take time.
    SoCal
    I haven't had it diagnosed with a legit scanner yet. I have an appt. with my mechanic on Tuesday. I found a good write up on Wayalife and it details all the steps to do the oil filter housing / cooler. I got a good look in there last night and it's not leaking oil in the valley area where everyone sees the leaks. I have a decent set of tools and it doesn't seem too hard I've just never delt with the intake before, gaskets, fuel rails etc. I was also reading about replacing the filter housing / cooler assembly to put in a 2014 or newer part # to use the new filter design. Any suggestions or advice on that issue? Thanks for the reply, doesn't seem like too much traffic on this site but you always seems to reply and have great advice, thank you!!
    SoCal
    Got it to my mechanic today. He pulled the intake off and the filter housing was not leaking at all. The valley was dry as a bone. He replaced the pressure sensor with a new Mopar one. He told me it looks like a completely different design so we're hoping it's an upgraded one that will last more thank 58k. He scanned it to read oil pressures, oil temps, and coolant temps and all checked out. He road tested it and no CEL. I'll pick her up tomorrow and see how she does.
    Justin
    Russia
    , 3 Oil pressure. Engine Off . , . . , ???
    Russia
    http://bit.ly/2JBFtzq
    п»ї*‘*µСЃ*ї*»*°С‚*Ѕ*°СЏ СЋСЂ*ё*ґ*ёС‡*µСЃ*є*°СЏ *ї*ѕ*ј*ѕС‰СЊ *ё*Ѕ*І*°*»*ё*ґ*°*ј. *“*ґ*µ *µ*µ *ї*ѕ*»СѓС‡*ёС‚СЊ?
    *љС‚*ѕ *ё*ј*µ*µС‚ *їСЂ*°*І*ѕ *Ѕ*° *±*µСЃ*ї*»*°С‚*ЅСѓСЋ СЋСЂ*ё*ґ*ёС‡*µСЃ*єСѓСЋ *ї*ѕ*ј*ѕС‰СЊ?
    *ћ*є*°*·*°*Ѕ*ё*µ *»СЋ*ґСЏ*ј СЃ *ё*Ѕ*І*°*»*ё*ґ*Ѕ*ѕСЃС‚СЊ Ћ *»СЊ*і*ѕС‚*ЅС‹С… СЋСЂ*ё*ґ*ёС‡*µСЃ*є*ёС… СѓСЃ*»Сѓ*і СЂ*µ*іСѓ*»*ёСЂСѓ*µС‚СЃСЏ *¤*µ*ґ*µСЂ*°*»СЊ*ЅС‹*ј *·*°*є*ѕ*Ѕ*ѕ*ј *ѕС‚ 21.11.2011 N 324-*¤*— "*ћ *±*µСЃ*ї*»*°С‚*Ѕ*ѕ*№ СЋСЂ*ё*ґ*ёС‡*µСЃ*є*ѕ*№ *ї*ѕ*ј*ѕС‰*ё *І ***ѕСЃСЃ*ё*№СЃ*є*ѕ*№ *¤*µ*ґ*µСЂ*°С**ё*ё" .
    *‘*µСЃ*ї*»*°С‚*Ѕ*ѕ *ѕ*є*°*·С‹*І*°*µС‚СЃСЏ СЋСЂ*ё*ґ*ёС‡*µСЃ*є*°СЏ *ї*ѕ*ј*ѕС‰СЊ *ё*Ѕ*І*°*»*ё*ґ*°*ј 1 *іСЂСѓ*ї*їС‹, *° С‚*°*є*¶*µ *ё*Ѕ*І*°*»*ё*ґ*°*ј 2 *іСЂСѓ*ї*їС‹. *ў*°*є*¶*µ *±*µСЃ*ї*»*°С‚*Ѕ*ѕ *ј*ѕ*іСѓС‚ *ї*ѕ*»СѓС‡*ёС‚СЊ СЋСЂ*ё*ґ*ёС‡*µСЃ*єСѓСЋ *ї*ѕ*ј*ѕС‰СЊ *ґ*µС‚*ё-*ё*Ѕ*І*°*»*ё*ґС‹ *ё *ё*Ѕ*І*°*»*ё*ґС‹, *їСЂ*ѕ*¶*ё*І*°СЋС‰*ё*µ *І *ѕСЂ*і*°*Ѕ*ё*·*°С**ёСЏС… СЃ*ѕС**ё*°*»СЊ*Ѕ*ѕ*і*ѕ *ѕ*±СЃ*»Сѓ*¶*ё*І*°*Ѕ*ёСЏ.
    *“*ґ*µ *ї*ѕ*»СѓС‡*ёС‚СЊ *±*µСЃ*ї*»*°С‚*ЅСѓСЋ СЋСЂ*ё*ґ*ёС‡*µСЃ*єСѓСЋ *ї*ѕ*ј*ѕС‰СЊ?
    *‘*µСЃ*ї*»*°С‚*ЅСѓСЋ СЋСЂ*ё*ґ*ёС‡*µСЃ*єСѓСЋ *ї*ѕ*ј*ѕС‰СЊ *ѕ*є*°*·С‹*І*°СЋС‚ *і*ѕСЃСѓ*ґ*°СЂСЃС‚*І*µ*Ѕ *ЅС‹*µ СЋСЂ*ё*ґ*ёС‡*µСЃ*є*ё*µ *±СЋСЂ*ѕ *ё *°*ґ*І*ѕ*є*°С‚С‹, СЏ*І*»СЏСЋС‰*ё*µСЃСЏ СѓС‡*°СЃС‚*Ѕ*ё*є*°*ј*ё *і*ѕСЃСѓ*ґ*°СЂСЃС‚*І*µ*Ѕ *Ѕ*ѕ*№ СЃ*ёСЃС‚*µ*јС‹ *±*µСЃ*ї*»*°С‚*Ѕ*ѕ*№ СЋСЂ*ё*ґ*ёС‡*µСЃ*є*ѕ*№ *ї*ѕ*ј*ѕС‰*ё.
    *Ў*ї*ёСЃ*ѕ*є *°*ґ*І*ѕ*є*°С‚*ѕ*І, *є*ѕС‚*ѕСЂС‹*µ *ѕ*є*°*·С‹*І*°СЋС‚ *±*µСЃ*ї*»*°С‚*ЅСѓСЋ СЋСЂ*ё*ґ*ёС‡*µСЃ*єСѓСЋ *ї*ѕ*ј*ѕС‰СЊ, *їСѓ*±*»*ё*єСѓСЋС‚СЃСЏ *Ѕ*° СЃ*°*№С‚*µ *і*ѕСЃСѓ*ґ*°СЂСЃС‚*І*µ*Ѕ *ЅС‹С… *ѕСЂ*і*°*Ѕ*ѕ*І *ё *°*ґ*І*ѕ*є*°С‚СЃ*є*ёС… *ї*°*»*°С‚. *ќ*°*їСЂ*ё*ј*µСЂ, *І *њ*ѕСЃ*є*І*µ С‚*°*є*ѕ*№ СЃ*ї*ёСЃ*ѕ*є *їСѓ*±*»*ё*єСѓ*µС‚ *”*µ*ї*°СЂС‚*°*ј*µ*ЅС‚ тру*ґ*° *ё СЃ*ѕС**ё*°*»СЊ*Ѕ*ѕ*№ *·*°С‰*ёС‚С‹ *Ѕ*°СЃ*µ*»*µ*Ѕ*ёСЏ *ё *ђ*ґ*І*ѕ*є*°С‚СЃ*є*°СЏ *ї*°*»*°С‚*° *і*ѕСЂ*ѕ*ґ*° *њ*ѕСЃ*є*ІС‹.
    *ў*°*є*¶*µ СЃ*ї*ёСЃ*є*ё *і*ѕСЃСѓ*ґ*°СЂСЃС‚*І*µ*Ѕ *ЅС‹С… *±СЋСЂ*ѕ *ё *°*ґ*І*ѕ*є*°С‚*ѕ*І, *ѕ*є*°*·С‹*І*°СЋС‰*ёС… *±*µСЃ*ї*»*°С‚*ЅСѓСЋ *ї*ѕ*ј*ѕС‰СЊ *ё*Ѕ*І*°*»*ё*ґ*°*ј, *їСѓ*±*»*ё*єСѓСЋС‚СЃСЏ *Ѕ*° СЃ*°*№С‚*µ Сѓ*їСЂ*°*І*»*µ*Ѕ*ё*№ *њ*ё*Ѕ*ёСЃС‚*µСЂСЃС‚*І*° *®СЃС‚*ёС**ё*ё СЃСѓ*±СЉ*µ*єС‚*° ***¤, *І *є*ѕС‚*ѕСЂ*ѕ*ј *’С‹ *їСЂ*ѕ*¶*ё*І*°*µС‚*µ.
    *Ў *ѕСЃ*µ*Ѕ*ё 2018 *і*ѕ*ґ*° *ї*ѕ*»СѓС‡*ёС‚СЊ *±*µСЃ*ї*»*°С‚*ЅСѓСЋ *є*ѕ*ЅСЃСѓ*»СЊС‚*°С**ёСЋ *їСЂ*ѕС„*µСЃСЃ*ё*ѕ*Ѕ*°*» Њ*ЅС‹С… СЋСЂ*ёСЃС‚*ѕ*І – "*•*ІСЂ*ѕ*ї*µ*№СЃ*є*ѕ* СЋСЂ*ё*ґ*ёС‡*µСЃ*є*ѕ*№ СЃ*»Сѓ*¶*±С‹" – *ј*ѕ*¶*Ѕ*ѕ *Ѕ*° *ї*ѕСЂС‚*°*»*µ. *”*»СЏ СЌС‚*ѕ*і*ѕ *ЅСѓ*¶*Ѕ*ѕ *·*°*ї*ѕ*»*Ѕ*ёС‚СЊ С„*ѕСЂ*јСѓ *ё *ѕС‚*їСЂ*°*І*ёС‚СЊ *І*ѕ*їСЂ*ѕСЃ *ї*ѕ СЃСЃС‹*»*є*µ. *ћ*±СЂ*°С‰*°*µ*ј *І*Ѕ*ё*ј*°*Ѕ*ё*µ, чт*ѕ СЋСЂ*ёСЃС‚С‹ *±*µСЃ*ї*»*°С‚*Ѕ*ѕ *їСЂ*µ*ґ*ѕСЃС‚*°*І*»СЏСЋ ‚ СѓСЃС‚*ЅС‹*µ *ё *ї*ёСЃСЊ*ј*µ*Ѕ*ЅС‹*µ *є*ѕ*ЅСЃСѓ*»СЊС‚*°С**ё*ё *ї*ѕ*»СЊ*·*ѕ*І*°С‚*µ*»СЏ *ј, *Ѕ*ѕ *Ѕ*µ СЃ*ѕСЃС‚*°*І*»СЏСЋС‚ *ґ*ѕ*єСѓ*ј*µ*ЅС‚С‹ *ё *Ѕ*µ СЃ*ѕ*їСЂ*ѕ*І*ѕ*¶*ґ*°СЋС‚ *І СЃСѓ*ґ*µ.
    *љСѓ*ґ*° *µС‰*µ *ј*ѕ*¶*Ѕ*ѕ *ѕ*±СЂ*°С‚*ёС‚СЊСЃСЏ *·*° *±*µСЃ*ї*»*°С‚*Ѕ*ѕ*№ *є*ѕ*ЅСЃСѓ*»СЊС‚*°С**ё*µ *№?
    *ќ*ѕС‚*°СЂ*ёСѓСЃС‹ *ѕ*є*°*·С‹*І*°СЋС‚ *±*µСЃ*ї*»*°С‚*ЅСѓСЋ СЋСЂ*ё*ґ*ёС‡*µСЃ*єСѓСЋ *ї*ѕ*ј*ѕС‰СЊ *іСЂ*°*¶*ґ*°*Ѕ*°*ј, *ѕ*±СЂ*°С‚*ё*ІС€*ё*јСЃСЏ *·*° СЃ*ѕ*І*µСЂС€*µ*Ѕ*ё*µ*ј *Ѕ*ѕС‚*°СЂ*ё*°*»СЊ*ЅС‹С *ґ*µ*№СЃС‚*І*ё*№, *° *ё*ј*µ*Ѕ*Ѕ*ѕ *є*ѕ*ЅСЃСѓ*»СЊС‚*ёСЂСѓСЋ ‚ *ї*ѕ *І*ѕ*їСЂ*ѕСЃ*°*ј СЃ*ѕ*І*µСЂС€*µ*Ѕ*ёСЏ СЌС‚*ёС… *ґ*µ*№СЃС‚*І*ё*№.
    *ў*°*є*¶*µ *±*µСЃ*ї*»*°С‚*ЅСѓСЋ *ї*ѕ*ј*ѕС‰СЊ *ѕ*є*°*·С‹*І*°СЋС‚ СЋСЂ*ё*ґ*ёС‡*µСЃ*є*ё*µ *є*»*ё*Ѕ*ё*є*ё *ё *Ѕ*µ*і*ѕСЃСѓ*ґ*°СЂСЃС‚*І *µ*Ѕ*ЅС‹*µ С**µ*ЅС‚СЂС‹ *±*µСЃ*ї*»*°С‚*Ѕ*ѕ*№ СЋСЂ*ё*ґ*ёС‡*µСЃ*є*ѕ*№ *ї*ѕ*ј*ѕС‰*ё.
    *®СЂ*ё*ґ*ёС‡*µСЃ*є*ё*µ *є*»*ё*Ѕ*ё*є*ё *їСЂ*µ*ґСЃС‚*°*І*»СЏСЋС‚ СЃ*ѕ*±*ѕ*№ сту*ґ*µ*ЅС‡*µСЃ*є*ё*µ *є*ѕ*ЅСЃСѓ*»СЊС‚*°С‚*ё*І *ЅС‹*µ *ё*»*ё СЋСЂ*ё*ґ*ёС‡*µСЃ*є*ё*µ *±СЋСЂ*ѕ – *ї*ѕ*ј*ѕС‰СЊ *·*ґ*µСЃСЊ *ѕ*є*°*·С‹*І*°СЋС‚ сту*ґ*µ*ЅС‚С‹ *їСЂ*°*І*ѕ*ІС‹С… *ё*ЅСЃС‚*ёС‚СѓС‚*ѕ*І *ї*ѕ*ґ *Ѕ*°*ґ*·*ѕСЂ*ѕ*ј *їСЂ*µ*ї*ѕ*ґ*°*І*°С‚*µ*» *µ*№. *’ *њ*ѕСЃ*є*І*µ, *Ѕ*°*їСЂ*ё*ј*µСЂ, С‚*°*єСѓСЋ *ї*ѕ*ј*ѕС‰СЊ *ѕ*є*°*·С‹*І*°*µС‚ *®СЂ*ё*ґ*ёС‡*µСЃ*є*°СЏ *є*»*ё*Ѕ*ё*є*° *’СЃ*µСЂ*ѕСЃСЃ*ё*№СЃ*є*ѕ *і*ѕ *і*ѕСЃСѓ*ґ*°СЂСЃС‚*І*µ*Ѕ *Ѕ*ѕ*і*ѕ Сѓ*Ѕ*ё*І*µСЂСЃ*ёС‚*µС‚*° СЋСЃС‚*ёС**ё*ё.
    *ќ*µ*і*ѕСЃСѓ*ґ*°СЂСЃС‚*І *µ*Ѕ*ЅС‹*µ С**µ*ЅС‚СЂС‹ *±*µСЃ*ї*»*°С‚*Ѕ*ѕ*№ СЋСЂ*ё*ґ*ёС‡*µСЃ*є*ѕ*№ *ї*ѕ*ј*ѕС‰*ё СЃ*ѕ*·*ґ*°СЋС‚СЃСЏ *І *І*ё*ґ*µ *Ѕ*µ*є*ѕ*ј*ј*µСЂС‡*µСЃ*є *ёС… *ѕСЂ*і*°*Ѕ*ё*·*°С**ё*№ *°*ґ*І*ѕ*є*°С‚*°*ј*ё, *Ѕ*ѕС‚*°СЂ*ёСѓСЃ*°*ј*ё *ё *ќ*љ*ћ. *Ў*ї*ёСЃ*ѕ*є С‚*°*є*ёС… С**µ*ЅС‚СЂ*ѕ*І *ѕ*їСѓ*±*»*ё*є*ѕ*І*°*Ѕ *њ*ё*Ѕ*ёСЃС‚*µСЂСЃС‚*І*ѕ *ј СЋСЃС‚*ёС**ё*ё ***¤ *Ѕ*° *ѕС„*ёС**ё*°*»СЊ*Ѕ*ѕ*ј СЃ*°*№С‚*µ.
    *ђ*ґ*І*ѕ*є*°С‚ *ћ*»*µ*і *˜СЃ*є*°*є*ѕ*І *ѕ*є*°*·С‹*І*°*µС‚ *їСЂ*°*І*ѕ*ІСѓСЋ *ї*ѕ*ј*ѕС‰СЊ *іСЂ*°*¶*ґ*°*Ѕ*°*ј *ё *ѕСЂ*і*°*Ѕ*ё*·*°С**ёСЏ*ј *І *ѕ*±*»*°СЃС‚СЏС… *іСЂ*°*¶*ґ*°*ЅСЃ*є*ѕ*і*ѕ, Сѓ*і*ѕ*»*ѕ*І*Ѕ*ѕ*і*ѕ, СЃ*µ*ј*µ*№*Ѕ*ѕ*і*ѕ *ё тру*ґ*ѕ*І*ѕ*і*ѕ *їСЂ*°*І*°.
    http://bit.ly/34ogyYf
    **J**
    http://bit.ly/2QbO2VS - Кредитная история. Оценка, исправления
    Russia
    http://bit.ly/2Px3xpc
    Наш сервисный центр объединяет мастеров, специализирующихся на ремонте крупной бытовой техники.
    Мы имеем в своих рядах только специалистов с подтвержденными навыками и опытом и гарантируем отличный результат ремонта при минимальных затратах.
    Специалисты компании ремонтируют холодильники, посудомоечные и стиральные машины популярных производителей.
    Мы специализируемся на выездном обслуживании, а это значит, что необходимые ремонтные работы выполняются на дому у заказчика, что избавляет от необходимости самостоятельного демонтажа и транспортировки вышедшей из строя техники в мастерскую.
    Использование оригинальных запасных частей и расходных материалов позволяет нам давать долгосрочную гарантию на все виды ремонта.
    Наши мастера аккуратны, вежливы и внимательны к пожеланиям клиента, способны быстро определить проблему в ходе бесплатной экспресс-диагностики и готовы приступить к ее решению немедленно.
    923f4a3
    Russia
    923f4a3
    Russia
    Майнинг жив!
    Знаете ли вы, что большую часть времени мощности вашего компьютера простаивают? Начните эффективнее использовать ресурсы своего компьютера и зарабатывать на этом! Просто скачивайте себе CryptoTab браузер и он будет майнить биткойны в фоновом режиме за счет неиспользуемых мощностей компьютера, пока вы просто сидите в интернете. Вот ссылка - http://bit.ly/2uZLOgc
    http://chilp.it/bd19107
    https://youtu.be/xN0IdF4ILp0
    Как начать майнить для начинающих crypto tab скачать 23f4a3b
    Russia
    **zz**
