DEAL OF THE WEEK! ALCON BIG BRAKES FOR JEEP WRANGLER DANA 40/60/70 FREE SHIPPING!
VIEW DEAL HERE!!
ALCON introduces the Jeep JK Wrangler Rear Heavy Duty Brake Kit. This kit represents a substantial upgrade in braking performance and includes features not found in any other kit. High temperature seals as used in Motorsports applications, dust seals for performance in the worst conditions, and a low profile designed to fit under your OEM wheels.
The ALCON front & rear big brake kit for 2007-2018 Jeep Wranglers offers unmatched performance both on and off road for your daily driver or purpose built trail rig. Utilizing massive 350mm front and 330mm rear rotors in conjunction with 4 piston calipers all around helps achieve up to 45% improved performance over the OEM brakes.
Here's the facts from ALCON:
-Gains in performance over stock braking systems
-Up to 30% reduction in disc temperature rise
-Up to 26% reduction in pad work rate
-Up to 25% reduction in pedal effort
-Ductile Iron caliper housing providing maximum strength and stiffness as well as high resistance to impact & fatigue
Features:
-Epoxy acrylic paint over acid zinc finish for maximum corrosion protection
-High friction pads significantly increase both stopping distance & stopping power
-Larger rotors increase brake torque and thermal capacity, reducing potential for brake fade
-Increased pad area reduces temperatures and increases pad life
-Retains & utilizes OEM parking brake
-Fits many 17" and larger aftermarket wheels
These kits include everything you need including lines, hardware, and performance brake pads! The kit is compatible with your stock master cylinder AND parking brake.
IF YOU HAVE ANY QUESTIONS PLEASE GIVE US A CALL AT 866-900-8841 TO SPEAK WITH A BUILD SPECIALIST.
