SCROLL DOWN FOR COMPLETE UPGRADE LIST AND MORE PICS!
REBEL OFF ROAD - COMPLETE JEEP JK COILOVER CONVERSION SYSTEM
KIT INCLUDES:
REBEL OFF ROAD - FRONT COILOVER CONVERSION SYSTEM (BOLT ON)
- FRONT UPPER AND LOWER COILOVER MOUNTING BRACKETS
- (2x) KING COILOVERS 2.5 12" STROKE WITH PROPRIETARY VALVING AND SPRING RATES
COILOVER BLACK ANO
REBEL OFF ROAD - REAR COILOVER CONVERSION SYSTEM (BOLT ON)
- REAR UPPER AND LOWER COILOVER MOUNTING BRACKETS
- (2x) KING COILOVERS 2.5 14" STROKE WITH PROPRIETARY VALVING AND SPRING RATES
COILOVER BLACK ANO
REBEL OFF ROAD - FRONT HYDRAULIC BUMP STOP CONVERSION SYSTEM (BOLT ON)
- FRONT UPPER RECON BUMP STOP BRACKETS
REBEL OFF ROAD EXCLUSIVE TERAFLEX LONG ARM UPGRADE FOR RECON COILOVER CONVERSION
BORLA CLIMBER EXHAUST SYSTEM
JE REEL FRONT 1350 DRIVESHAFT DOUBLE CARDAN STYLE SHAFT
JE REEL REAR 1350 DRIVESHAFT DOUBLE CARDAN STYLE SHAFT
TERAFLEX HD TIE ROD AND DRAG LINK
TERAFLEX FALCON NEXUS 2.1 STEERING STABILIZER
REBEL OFFROAD - REAR HYDRAULIC BUMP STOP KIT (WELD IN)
CURRIE ANTIROCK REAR SWAY BAR KIT WITH ALUMINUM ARMS
DIRTYLIFE ROAD KILL FULL BEADLOCK 17X9 5x5
37X12.50X17 TOYO OPEN COUNTRY MT
CURRIE ROCK JOCK 44
-RockJock 44 high-pinion nodular-iron center section with thicker walls and webbing
-Larger/stronger Dana 44 8.8 late model JK ring and pinion set
-1350 u-joint
-3 inch diameter, .375 wall DOM tube
-Currie Performance 4340 chromoly inner/outer axles with 1350 u-joints
-Heavy gauge 3/16 laser cut steel brackets
-Upper control arm mounts include rebuildable Johnny Joints, Lower control arm mounts are 1 piece construction with integrated skid plate
-Optimized for 4 lift kit with 5 degrees of pinion angle to reduce driveshaft angle and 5 degrees of caster for improved steering
-65.375 inches between wheel mounting surfaces (stock JK width)
-5 on 5 inch with 1/2 inch studs (standard JK pattern)
-Black satin powder coat
-ARB Air Locker
DANA 60 REAR 40 SPLINE ROCK JOCK AXLE - CURRIE
-STANDARD WIDTH TO MATCH ROCK JOCK 44 FRONT HOUSING
- 40 SPLINE AXLES (SUPER HEAVY DUTY)
- ARB AIR LOCKER (40 SPLINE)
- 4:88 GEARS
-1350 YOKES
- 5 ON 5 LUG PATTERN
ARB TWIN AIR COMPRESSOR
ARB MANIFOLD FOR COMPRESSOR
M.O.R.E. UNDERHOOD COMPRESSOR MOUNT
FRONT CURRIE ANTIROCK SWAY BAR
SPOD 6 SOURCE SYSTEM WITH LEGENDS LABEL AND ADAPTER FOR ARB COMPRESSOR
POISON SPYDER SOLID INNER FENDERS - POWDERCOAT INNER FENDERS
ROCKHARD 4X4 TRANSMISSION AND OIL PAN SKID PLATE
ROCKHARD 4X4 TRANSFER CASE SKID PLATE
ROCKHARD 4X4 GAS TANK SKID PLATE
ROCKHARD 4X4 EVAP SKID PLATE
