Results 1 to 7 of 7
    Rogersville Tn
    2.5" TF kit installed!!
    I'll try and get pictures tomorrow but I got it installed with the AEV Geometry brackets, man it rides great and it's not darty at all. It rides better than it did when stock. I'll put about 500 miles or so on it and go back over the bolts and check the tq again but going to get the Cooper Discovery Pro STT 295/70/18's on this evening after work. Can't wait to see it with the tires.
    I got the $748 kit that came with the TF shocks etc. and I added TF stabilizer shock, added the AEV brackets for good measure and glad I did. The steering is just a hair to the left but a quick trip to the alignment shop will cure that.
    Now my friends hollering detachable sway bar links, do we need them?
    Depends on what you plan on doing with the rig.
    If it's strictly a daily driver, then you don't need the sway bar disconnects. If you take it off road, it helps a lot, especially in situations where you are crawling on rocks.
    Banned
    NE Ohio
    Congrats on the new lift!
    Also, if by "steering is a bit to the left" you mean the steering wheel is off center this can be easily fixed by just adjusting your draglink. Although an alignment is never a bad idea after a lift.
    Rogersville Tn
    Well I got it to the shop and all is good, we did get the steering straight and the rest checked out great.
    Looking good!!
    Fl
    Not really required but adding a detachable swaybar endlinks make a huge improvement when tackling bumpy/washboard roads.
    Rogersville Tn
    Quote Originally Posted by carlos1 View Post
    Yea thats what I hear, may have to purchase some of those.
