Results 1 to 10 of 10
    Authorized Freak Vendor REBEL OFF ROAD's Avatar
    Southern California
    Rebel Off Road- Complete Jeep JK Coilover Conversion System
    2017 JKUR on the rack getting installed our complete coilover conversion system. Our coilover system includes:
    Rebel Off Road-Front Coilover Conversion System
    -Front upper and lower coilover mounting bracekts
    -(2x) King Coilovers 2.5 12" stroke with proprietary valving and spring rates
    -90 degree fittings
    -Grade 8 hardeware
    Rebel Off Road-Rear Coilover Conversion System
    -Rear upper and lower coilover mounting brackets
    -Grade 8 haradware
    Rebel Off Road- Front Hydraulic Bump Stop Conversion System
    -Front upper recon bump stop brackets
    -Grade 8 Hardware
    Rebel Off Road // Bond Gilmer, President
    Toll Free: 866-900-8841
    Email: info@rebeloffroad.com
    HQ: www.rebeloffroad.com
    CONSULT. BUILD. DELIVER.
    Southern California
    Rebel Off Road Exclusive Teraflex Long Arm Upgrade For Recon Coilover Conversion
    -8 Arm Upgrade
    -Drag Link Flip Kit
    -Front Track Bar
    -Rear Track Bar
    -Weld on Long Arm Brackets
    -Brake Lines
    Southern California
    Rear Sway Bar
    -Currie Antirock Rear Sway bar kit with Aluminum Arms
    Exhaust System
    -Borla Climber Exhaust System
    Driveshafts
    -JE Reel Front and Rear 1350 Driveshafts Double Cardan Style Shafts
    Teraflex HD Tie Rod and Drag Link
    Southern California
    Dana 60 Rear 40 Spline Currie Rock Jock Axle
    -Standard width to match Rock Jock 44 front housing
    -40 Spline Axles (Super Heavy Duty)
    -ARB Air Air Lockers (40 Spline)
    -4:88 Gears
    -Master Bearing Kit
    -Brackets (Track Bar etc.)
    -01350 Yokes
    -5 on 5 Lug pattern
    [IMG][/IMG]
    Southern California
    More Goodies!!
    Second day of this build and we have installed a few components under the hood and in the interior.
    Compressor System for air lockers
    -ARB Twin Air Compressor
    -ARB Manifold for compressor
    -M.O.R.E Underhood Compressor mount
    SPOD 6 source system with legends label and adapter for ARB compressor
    Daystar lower switch panel
    Southern California
    Front Sway Bar
    -Front Currie Antirock Sway Bar with aluminum arms
    Southern California
    Inner Fenders
    We have just placed Poison Spyder Front Inner Fenders specifically modified to fit our Recon Kit.
    Southern California
    Front Axle
    We have just put the last piece to the front axle puzzle!!Here is what we have u in the front:
    Currie Rock Jock 44
    -RockJock 44 high-pinion nodular-iron center section with thicker walls and webbing
    -Larger/Stronger Dana 44 8.8" late model JK ring and pinion set
    -1350 u-joint
    -3-inch diameter, .375 wall DOM tube
    -Currier Performance 4340 Chromoly inner/outer axles with 1350 u-joints
    -Heavy gauge 3/16" laser cut steel brackets
    -Upper control arm mounts include rebuildable Johnny Joints, Lower control arm mounts 1 piece construction with integrated skid plate
    -Optimized for 4" lift kit with 5 degrees of pinion angle to reduce driveshaft angle and 5 degrees of caster for improved steering
    -65.375 inches between wheel mounting surfaces (stock JK width)
    -5 on 5 inch with 1/2 inch studs (Standaard JK pattern)
    -Black Satin powder coat
    -ARB Air Locker
    -Teraflex D44 Front Ball Joint Set
    Southern California
    LET US NOT FORGET ABOUT THE WHEELS AND TIRES!
    For this build we have used 17x9 Dirtylife Road Kill Full Beadlocks wrapped in 37" Toyo Open Country Mud Terrains. Spaced with G2 1.5 Wheel Spacers.
    Southern California
    Morning Stretch
    Flex test on #AllBlackEverythingJKU!
