All new for 2018!
More info: http://www.rockhard4x4.com/product_p/rh-5050.htm
Fits all 2007 - 2018 Jeep Wrangler JK 2/4DR
The perfect solution if you're looking to run larger than factory tires but don't want to have to install a bumper mounted tire carrier! Our Freedom Series Body Mount Tire Carrier replaces the limited hinges on your tailgate with our extreme duty complete tire carrier replacement.
Easy to install with zero cutting, drilling, or welding required. The tailgate operates just like factory using the factory handle to open and shut the tire carrier. Heavy duty bronze oil lite bushings and massive 1/2" bolts firmly secure the tire carrier to our 1/4" thick steel hinge side mounting brackets.
Works with virtually all aftermarket rear bumpers including factory.
Features
  • Supports up to 37" spare tire plus accessories
  • 100% bolt-on design
  • ZERO drilling or cutting required
  • Powder coat included
  • All hardware included
  • Exclusive bronze oil lite bushings and 1/2" pins
  • Adjustable spare tire mount for clearance / visibility
  • Hi-Lift jack mount included
  • CB antenna mount included
Specifications
  • Tire Carrier Weight: 50 lbs.
Accessories:
Cargo Basket: http://www.rockhard4x4.com/product_p/rh-5053.htm
Pass Side Tank Mount: http://www.rockhard4x4.com/product_p/rh-5052.htm
Driver Side: (Coming Soon)
