Results 1 to 9 of 9
    knoxville
    Help! Horn problem 2012 Jeep Wrangler Rubicon
    I have a 2012 Rubicon Unlimited and when I alarm my Jeep, or open a door the horn blows for about 60 seconds and quits. Both horn fuses are good, no lights on dash, and all my steering wheel controls work just fine. With the fuses in I have no horn if I press on the steering wheel and when I alarm my Jeep from the horn chirps like normal. Right now I have fuse M23 pulled until I figer this out. Any ideas what my problem is?
    It could be the TIPM (Total Integrated Power Module) itself. I've heard of weird things like this with a bad TIPM, like wipers that won't turn off.
    Try disconnecting the battery for an hour and reconnecting (rebooting the system) and see if that helps.
    knoxville
    I did disconnect the battery little over 10 minutes and didn’t help. I will try that for a hour.
    knoxville
    I disconnected the battery for over a hour, did not fix the horn from blowing, as soon I touched the battery terminals the horn immediately started to blow.
    Soy un perdedor
    Inigo Montoya's Avatar
    Norte de Tejas
    Quote Originally Posted by ShutterBug View Post
    Agree with the TIPM. Could be shorted out.
    Sent via Wonkavision
    I just saw three people jogging outside my window and it inspired me... to get up and close the blinds.
    knoxville
    If it was the TIPM, would I have lights on the dash and other components on the steering wheel not work too? Seems very odd only having a horn issue, cruise, and all steering wheel buttons work.
    MallCrawler Free Booter's Avatar
    United States
    I found this in the Wrangler Forum posted by "KBWOLF"
    "Whoa, found a veritable plethora of threads. Water seems like the most likely culprit:
    Horn randomly blows https://www.jk-forum.com/forums/stoc...-blows-161650/
    horn honks when wet https://www.jk-forum.com/forums/stoc...en-wet-240682/
    Horn Honking By Itself http://www.jeepforum.com/forum/f96/h...itself-863239/
    stupid horn!!! http://www.wranglerforum.com/f282/stupid-horn-8488.html
    and the original thread: http://www.wranglerforum.com/f274/ho...ff-184979.html
    Maybe it will help?
    2012 JKU Rubi - PX8 Dual Top, Rock Krawler 4" X-Factor lift w/Bilstein 5160, 35" Nitto Terra Grappler M/Ts, 20" Fuel Lethal Rims, Grille mesh inserts,
    Black Jeep Emblem,Rugged Ridge-Performance Hood, JCR Offroad Defender Mid Width Winch Bumper W/ Skid plate & Rear Bumper/Shield Tire Carrier, Ace Rock Sliders,
    12k Synthetic Engo Winch,Cargo shelf, roll-bar mounted 48" Hi-Lift & Extinguisher,
    Tereflex bump Stops, Front/Rear Adams 1310 Driveshafts w/solid joints, Custom Decals
    knoxville
    It was the clock spring, dealer replaced it, the cruise control switch and horn switch. All good now!
    North Carolina
    I have a 2012 sport and my clock spring had to be replaced under warrantee it may be a problem with all 2012’s
