Results 1 to 8 of 8
    Authorized Freak Vendor REBEL OFF ROAD's Avatar
    Southern California
    2016 Jeep JK Wrangler Phase One Build 75th Anniversary "Bronze Tanner"
    2016 JEEP JK WRANGLER PHASE ONE BUILD 75TH ANNIVERSARY BRONZE TANNER
    Axles:
    DANA 60 FRONT ROCK JOCK VXR AXLE - CURRIE ENTERPRISES
    - ARB AIR LOCKER
    - CUSTOM WIDTH FOR 37 INCH TIRES
    - F450 KNUCKLES
    - HEAVY DUTY TIE ROD
    - 5:38 GEARS
    - MASTER INSTALL KIT W/ BEARINGS
    - ALL BRACKETS INCLUDED
    - 1350 YOKES
    - 6 ON 5.5 BOLT PATTERN
    - DIFFERENTIAL COVER
    DANA 70 REAR ROCK JOCK AXLE
    - ARB AIR LOCKER
    - FULL FLOAT
    - 5:38 GEARS
    - ARB LOCKER
    -40 SPLINE
    -1350 YOKE
    -6 ON 5.5 BOLT PATTERN
    -DIFFERENTIAL COVER
    Air Compressor:
    ARB AIR LOCKER MANIFOLD KIT
    ARB INFLATION ACCESSORY KIT
    ARB TWIN AIR COMPRESSOR
    MORE OFFROAD ARB TWIN AIR COMPRESSOR MOUNT
    AEV PRO CAL
    Driveshafts:
    FRONT JE REEL 1350 CUSTOM DRIVESHAFT
    REAR JE REEL 1350 CUSTOM DRIVESHAFT
    Suspension:
    CURRIE ENTERPRISES ANTIROCK ALUMINUM FRONT SWAY BAR KIT
    CURRIE ENTERPRISES ANTIROCK ALUMINUM REAR SWAY BAR KIT
    RECON FRONT BOLT-ON HYDRAULIC BUMP STOP MOUNTS (PAIR)
    RECON FRONT COILOVER MOUNTS FOR 12" 2.0 / 2.5 COILOVERS
    RECON KING AIR BUMPSTOP 2.0 4" (LIMITED TO 2") - BLACK FINISH
    RECON KING COILOVER 2.5 12" REBEL SPEC
    RECON KING COILOVER 2.5 14" REBEL SPEC (REAR ONLY)
    RECON KING COILOVER COMPRESSION ADJUSTER 2.5 (EACH)
    RECON KING COILOVER INTERNAL BYPASS (2.5 ONLY) (EACH)
    RECON REAR BOLT-ON 14" COILOVER MOUNTS
    RECON REAR WELD IN BUMPSTOP MOUNTS
    REBEL OFF ROAD EXCLUSIVE TERAFLEX LONG ARM UPGRADE FOR RECON COILOVER CONVERSION
    Brakes:
    REBEL OFFROAD-RESTRAINT COMPLETE BRAKE KIT (DANA 60 AND 70)
    KIT INCLUDES:
    - 2x RESTRAINT FRONT ROTORS (DOUBLE DRILLED & SLOTTED)
    - 2x RESTRAINT REAR ROTORS (DOUBLE DRILLED & SLOTTED)
    - 1 SET OF FRONT PADS
    - 1 SET OF REAR PADS
    Bumpers:
    POISON SPYDER ROCKBRAWLER II REAR BUMPER WITH TIRE CARRIER
    RIGID D SERIES PRO FLOOD DIFFUSED
    Wheels and Tires:
    METHOD RACE WHEELS
    - 101 BEADLOCK
    TOYO OPEN COUNTRY M/T 37X13.50R17
    Exhaust:
    BORLA CLIMBER CAT BACK EXHAUST SYSTEM
    Hood:
    DV8 HOOD Paint Matched
    Shifter:
    B&M Short Throw Shifter
    Seat Recline Kit
    J.W. SPEAKER LED JEEP TURN SIGNALS MODEL 239 J2 SERIES
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    Rebel Off Road // Bond Gilmer, President
    Toll Free: 866-900-8841
    Email: info@rebeloffroad.com
    HQ: www.rebeloffroad.com
    CONSULT. BUILD. DELIVER.
    MallCrawler Free Booter's Avatar
    United States
    Nice suspension mods. I like the color choices too. Very subtle and subued.
    2012 JKU Rubi - PX8 Dual Top, Rock Krawler 4" X-Factor lift w/Bilstein 5160, 35" Nitto Terra Grappler M/Ts, 20" Fuel Lethal Rims, Grille mesh inserts,
    Black Jeep Emblem,Rugged Ridge-Performance Hood, JCR Offroad Defender Mid Width Winch Bumper W/ Skid plate & Rear Bumper/Shield Tire Carrier, Ace Rock Sliders,
    12k Synthetic Engo Winch,Cargo shelf, roll-bar mounted 48" Hi-Lift & Extinguisher,
    Tereflex bump Stops, Front/Rear Adams 1310 Driveshafts w/solid joints, Custom Decals
    Southern California
    Quote Originally Posted by Free Booter View Post
    Thank you. We were really happy with how it turned out.
    Supporting Freak Hook-em's Avatar
    I gotta say, you guys do it right. I agree on the color choices. Just beautiful.
    Southern California
    Quote Originally Posted by Hook-em View Post
    Thank you. It's nice to see some different colors from time to time.
    Southern California
    Bronze tanner build - phase two!!
    Bronze Tanner came back for some more upgrades and goodies!
    Artec Inudstries Nighthawk JKU Sliders - CT Bronze Powdercoated
    Poison Spyder Bruiser Bumper - CT Bronze Powdercoated
    KC Hilites G34 LED Pair
    Warn Industries Zeon Platinum 12000lb Winch
    Warn Spydura Synthetic Line
    Poison Spyder Aluminum Hawse Winch Fairlead - Mojave Sand Painted
    RockHard 4x4 Bolt-in Sport Cage w/ rear center cross bar - Mojave Sand Painted
    Alcon D60 Big Brake Kit
    PSC Steering JK Ram Assist Steering Kit
    3/4 D Rings w/ Daystar D Ring Isolators
    Factor 55 Red Pro Link Loaded
    Dawson City, Yukon, Canada
    In my understanding, the original color of the DV8 Hood was black before you repainted it?
    I'm interested in that DV8 for myself.
    United States
    Was probably a black gel coat or primer (assuming it is fiberglass?). A lot of after market unpainted hoods come that way, but I could be wrong.
