Results 1 to 8 of 8
    CA
    axles for jku sport upgrade
    Hey jk freaks i'm looking to upgrade my 2016 jku with some rubicon locking axles or 1tons that i can fabricate to work. I found a guy selling axles off his 2001 ford f350 and i was wondering if these would be a good choice. Give me some advice here guys as i'm new at this jeeping thing.
    Rubicon axles come up every now and again. Just keep an eye on the forums, Craigslist and Fakebook. They usually go pretty fast if they are reasonably priced.
    I know tons can be used on a Jeep (they are typically wider than JK axles) but I'm not sure which ones work the best. You'll find several threads around (look for Fusion4x4's thread) on builds that used tons. Also, You might also contact Artec and other manufacturers that make swap kits. They may be able to tell you what axles will work.
    knoxville
    What is your budget?
    CA
    Quote Originally Posted by rlm007 View Post
    Well I’m hoping to get it all done for under 5,000. That’s axles,gears and lockers.
    CA
    I’m seriously considering buying a set of 2001 Ford 350HD axles for $1200. It’s got a Dana 60 in frt. and a Sterling 10.5 in the rear. What do you all think. Is this a good choice? I’d like to go with 5.38 gears and Eaton e-lockers. And run 38” tires.
    MallCrawler aven2rus's Avatar
    Lake Ariel, PA
    Here is the route I went to maintain it as a daily driver and have not experienced any issues running 37's other than the unrelated steering box. I run a Tru Trac LSD
    Before the D30 haters get started, I have friend who did the same only CTM's and ran Arkansas Off-road Park a dozen times, Moab Easter Jeep (Potato Salad Hill), Silverton CO twice and no issues. He also drives these trip from Monroe LA. Rund OX Lockers.
    My only regret is not welding on the lower control arm skids when it was out of the jeep. They sit on the shelf to this date.
    http://www.jkfreaks.com/forums/showt...-Edition/page4
    Front & Rear Cost Minus the Steering and Ball Joints
    Synergy Axle Gussets SYN8009-07 1 $69.99
    Nitro Dana 30 Axle Sleeves AXD44JK-SLEEVE 1 $119.99
    Alloy USA 4:88 Ring & Pinion Kit 360003 1 $1,132.99
    Alloy USA Dana 30 4340 Chomoly axle shaft kit w/ujoints 12152 1 $952.99
    Alloy USA Dana 44 Chomoly axle shaft kit 12156 1 $641.99
    $2,917.95
    Everything Front and Rear
    Alloy USA Dana 30 4340 Chomoly axle shaft kit w/ujpint 12152 1 $952.99
    Skyjacker Dual Load JK Ball joint JK2717B 1 $649.98
    Skyjacker HD JK Tie Rod JK717TR 1 $499.98
    Skyjacker HS JK Drag Link JK717DL 1 $374.98
    $4,442.89
    2016 Jeep Wrangler Unlimited Willys Edition - Skyjacker 4" w/M95 Series Monotubes & Lower Flex Arms, Skyjacker HD Steering & Dual Load Ball Joints, Synergy Gussets, Nitro Sleeves, Truetracs, 4:88's, USA Alloy Chromoly Axles F&R, Magnaflow High clearance Exhaust & Loop Delete, MORE Engine & T-Case Skids, Painless Trail Rocker, Rigid Industries Lighting, ESP Delete, Poison Spyder Aluminum Fares, AGR Hydro Assit. See build thread for details.
    Lake Ariel, PA
    [QUOTE=Before the D30 haters get started, I have friend who did the same only CTM's and ran Arkansas Off-road Park a dozen times, Moab Easter Jeep (Potato Salad Hill), Silverton CO twice and no issues. He also drives these trip from Monroe LA
    QUOTE]
    Potato Salad Hill Moab, Those you who know trail know this does it no justice. Had all those buggies at the bottom shocked. This a short arm 3.5" kit.
    https://www.facebook.com/skyjackersu...4104425899706/
    That's not a hard trial. Its really just a momentum climb. There is a guy with an old Toyota that runs that back wards. A 4 door jeep with the longer wheel base climbs it even easier.
