Results 1 to 10 of 10
    Supporting Freak mav204's Avatar
    Akron, Ohio
    JKS Quicker Disconnects
    I have the JKS Quicker Disconnects, all 4 bolts came lose over the past 3 years; the only way to tighten them is to put a screw driver on the pin hold and torque it down. In the process I broke my craftsman screw driver. What are you all using that is strong to get torqued down?
    Freak of Knowledge e-jeep's Avatar
    Maryland
    Try some loctite
    Want Jeep Mods? Marcus Has Them!! ~ River City Offroad
    Adrenaline Offroad ~ Best Jeep shop in the Washington DC area!!
    Akron, Ohio
    I did use red loctite, I am looking for recommendations on how to torque down on the nut without spinning the where to disconnect attaches to
    Post a picture.
    Supporting Freak bradm's Avatar
    Delaware, Ohio
    Alignment punch, maybe? Probably stronger than a screwdriver
    Sent from my Galaxy S7 using TapaTalk
    2011 Black Sahara Unlimited
    4" FrankenLift
    37" MTR/Ks on black 17" ProComps
    DIY Hydro-Assist Steering
    Rubicon front axle with Yukon 5.13's
    Rear Eaton E-Locker with Yukon 5.13's
    Akron, Ohio
    om the backside is an 19MM bolt, and you put the screwdriver (now broken) through the hole and torque down. These came lose a second time this year and added red lock tight now
    Red Loctite should do the trick. Maybe vise grips on the one end rather than the screw driver. But I think the Loctite should be all you need.
    Akron, Ohio
    Vice grips started to skuff up the pin. So we stoped. Seams only way is a screwdriver.
    MallCrawler Mallicon's Avatar
    NE Ohio
    I had a similar version of disconnects and did what BradM stated. Used a good quality punch and a Nyloc nut. I never had any issues with them loosening. The Nyloc nut will keep it from backing off, although the Loctite should work as well.
    2014 JKUS | Lift | Wheels | Tires
