Results 1 to 10 of 13
    Idaho
    Well built Rubicon axles, 5.38, ProGrip, 1 ton steering, 37 Cooper STT Pro
    My 3.8 already hated life and finally gave up a cam bearing. Might as well perform an LS swap. Only reason to sell is I need different gearing and already have a set of D60s in my garage waiting on a project.
    2007 Rubicon with 51k miles, Located in Boise ID.
    Complete axles front and rear (will not separate) $5000 or $5500 with front Artec truss installed. Less than 1,000 miles since complete overhaul.
    Crowne Extended stainless steel brake hose kit for 6" lift
    Dynatrac ProGrip big brake system, powder coated brackets and painted calipers (new)
    Yukon 5.38 gear sets
    Motive Gear master install kits
    Barnes 4x4 Heavy duty differential covers
    Barnes 4x4 diff cover heavy duty hardware
    Alloy USA heavy duty ball joints
    EVO rear rockstar skids/shock relocation
    Metal Cloak front shock relocation
    Steering: $400 (only available after the axles sell)
    SPON Mountain Goat Series Extreme Duty Tie Rod
    SPON Mountain Goat Series High steer correction kit
    Fox steering stabilizer
    Fox stabilizer bracket
    Oliver's Driveshafts $750
    1310 Double Cardin Front/Rear drive shaft with HD yokes
    Wheels/Tires Set of 4 80% $1800
    Black Rhino 20x10 Mint Gloss Graphite slight rock rash but balance true)
    Cooper 37x13.50R20 STT Pro Mud Terrain Tires
    42RLE auto trans. $500
    Engine parts:
    Red Rock 4x4 cold air intate $100
    OBX headers $100
    Fresh rebuilt 140A Alternator $150
    A/C Compressor $100
    Radiator $50
    Fredericksburg, VA
    Would you be open to shipping the axles? Can you shoot me some pics?
    Idaho
    Yes, I can ship the axles.
    Long Island
    would you part out the truss and progrips
    Idaho
    Potentially. PM me an offer
    Idaho
    I have received a lot of questions on why my price is so high for 'stock' axles. Not sure is anyone is really reading the detail list so here is a break down:
    Here is where I came up with a fair value.
    Extended stainless steel brake hose kit for 6" lift Crowne $104.99
    ProGrip big brake system Dynatrac $995.00
    Rear 5.38 gear set Yukon $271.55
    Front 5.38 grear set Yukon $271.55
    front master install kit Motive Gear $104.99
    rear master install kit Motive Gear $108.99
    Heavy duty differential covers front and rear Barnes 4x4 $220.00
    diff cover heay duty hardware Barnes 4x4 $16.00
    Installation labor for gears Boise 4x4 $950.00
    Front axle armor Artec $299.95
    Rear LCA skids and shock relocation EVO $124.99
    Total $3343.02
    I have sold 3 stock axle sets for $4,000 ea
    Idaho
    Headers back up for sale.
    Idaho
    New option: Willing to sell the axles minus brakes and knuckles for $4k
    You get Rubicon housings, e-lockers, Yukon 5.38 gears, all new bearings and seals. Bolt on your knuckles (dana 30 front is the same) and good to go.
    alabama
    Dobthese axles have c gussets along with the truss kit and the knuckles set up for high steer? I dont need the breaks. And they have the stock lockers? Im very intrested do you have pics?
    Idaho
    Axles have c gussets and artec truss kit front and rear are being welded on right now, knuckle set up for high steer. email me and I can send pics. clarkkenthill at gmail
