Results 1 to 10 of 13
    Lantana Florida
    installed my Metalcloak 3.5" lift
    Only got about 15'miles since done but so far much more stable no diving when on the brakes and seems to handle corners better :-) took me all day by myself but it's a great kit and fits great.
    Quote Originally Posted by racerx296 View Post
    Metal Cloak makes very good stuff, you will be very happy with the kit, just check all the torque values after 200 miles once it settles in
    Freak In Nature GreyGoose's Avatar
    New Jersey
    I have been looking at this kit for some time ... Any issues with clearances or anything else you needed than what came with the kit ?
    2015 JKUR
    JCR bumper
    Mce fenders
    Evo leveling kit
    35 inch Km2
    Lantana Florida
    Quote Originally Posted by GreyGoose View Post
    Mine is the rocksport game changer 3.5". The only thing you need is brake fluid and a day to install. I will try to post some pictures in the morning, it's on 35" tires with 18x10 rims no clearance issues at all on a two door!
    Lantana Florida
    Quote Originally Posted by ECHO View Post
    Will do a check for sure. I would agree very high quality parts that fit.
    Ramona California
    Picked up the 3.5 Game Changer with the Fox shocks over Black Friday weekend. What Back Space did you get on your wheels? MC is recommending 4 or less which sounds like much. The wheels I am looking at are Black Rhino 17 with 4.5 back spacing. I want to put 35 KO2 on them. How about the drive shaft? To you replace it? Looking forward to start wrenching just want to make sure I get everything I need.
    Thanks
    You should be fine with 4.5" of BS with 35's. You are going to sit higher then you need to with 35" tires and you can run a new driveshaft or do the exhaust spacer for the extra cleracne you need. They may be saying 4" or less with that kit because it is better suited for 37" tires which would need the smaller back spacing.
    Supporting Freak DeReK_AgIn's Avatar
    Norfolk VA
    i run the 4.5 MC its a GREAT lift, beats the crap out of my old RK lift.
    MallCrawler marcspaz's Avatar
    Virginia
    Great choice!
    I have the MC 3.5" Game Changer with the RockSports too. Way better than tha factory suspension. I have about 6,000 miles on it now. Feels just as good as the day it went in.
    _______oooo
    /¯¯¯|¯¯\¯¯¯¯\,____
    L/¯¯\\_ |"/¯¯¯(ºlllllllº) 2016 Rubicon Hard Rock!
    _(¯))==))..(¯))==))
    Quote Originally Posted by DeReK_AgIn View Post
    What do yo like better over the RK kit? Which RK kit did you run?
