    usa
    passenger door issue- locksmith?
    I was cruising nicely on the highway when I heard the noise from the passenger side door. So I pulled over to have a look.. the rear door is loose and I canít even unlock it now.. I don't know how it happened. Should I call a locksmith?
    Freak Scholar karls10jk's Avatar
    36į N
    What do you mean by the door is loose? Hinges on the door, hinges on the body, the striker, the lock cylinder??
    Toronto< ON
    IMO you should try to fix it yourself. You have to locate what have actually been broken - a lock or hinges. If it`s hinges look for a replacement or re-install them, maybe they loosed a bit
    [edit] i didnt saw a date of the topic. My bad. I guess, you dont need an advice anymore.
