Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Troy, NC
    I am new to the forum and have found a lot of great info.
    I have a 2011 4door unlimited Sahara with a 2.5 inch lift and have been told that I could run a BFG 275/70R18 on the 18x9 XD Rockstar II's with 30mm offset with no rubbing and the rubber will be inside the fenders...is this correct?
    Will the 275/70R18 tires rub?
    Will the 18x9 with 30mm offset keep the wheels inside the fender to prevent road grim and rock blowback on the jeep?
    How will this look and or opinions?
    Thanks guys!
  2. #22
    Troy, NC
    I have a 2011 JK with a 2 to 2.5 inch lift. I was told 18x9 with +30 offset was the way to go, but I'm now being told +30 is not and that a 0 offset is what I need. I would like to keep the wheel and tire combo close to under the fenders. What offset is right for this setup? Thanks in advance.
  3. #23
    ks
    Ok I am a female and have a2011 wrangler jeep unlimited with 3" lift, currently have 22575R16 tires, I am not sure on the tire size I can go up to
  4. #24
    Freak of Knowledge ShutterBug's Avatar
    Mentor, OH
    I'm not sure what being a female has to do with tire size.
    But, if the only thing you did was lift the Jeep, 35" tires should fit, but may rub the fenders when articulating off road. 33s should fit just fine.
    If you have flat fenders, 35s will fit no problem.
    2014 Black JK Sport-icon - My "Lil' Mule"
    JCR Offroad | Rock Krawler | Barnes 4WD | Artec | RCV | Ten Factory
    My Build Progress
  5. #25
    Quote Originally Posted by shoop74 View Post
    Welcome to the Forum! Tell us a bit more about what your going to be doing with your Jeep? Daily Driver, trails? both?
