Nice write-ups. Thank you!
Despite the possible lack of strength when compared to chromoly I may give it a try. I don't have a TIG machine or experience with chromoly anyhow.
I'm already pretty sure of the answer but those ends won't work with 15" wheels will they?? I wish I could find an upgrade that works with 15's! I'm not going ot 17's until I can get a bigger lift and put 37's on. But I'm tired of bending the garbage stock tie rod constantly.
'07 Unlimited Rubicon. Red Rock Crystal. RC 2.5" spacer lift, 15x8 MB72's wrapped in 35" MT/R's with Kevlar, Riddler diff covers, PSC evap skid, Poison SPyder BFH bumpers front and rear, cut factory flares, sleeved and gusseted front axle, synergy tie rod and drag link.
that is correct. I had to wait until I upgraded from 15's so I could slap these guys together.
And just a little update: Ruff Stuff has a new style standard 1-ton end that is no where near as strong as the old style. Had a new style on the pitman arm that failed in about 3 months, but the older one on the knuckle end is just as tight as day one. Just food for thought.
Thank you for giving me the heads up and reaffirming what I thought. I was pretty sure they wouldn't fit with 15's.
Hi, is the question of running 15s based on the backspacing or will the offset ends just not work with any 15" wheel? I'm running 3.75" backspace.
How do you adjust the draglink? Take it off every time?
just knock one TRE out and make your adjustment. Its a bit of a pain but this thing isnt going to bend anytime soon so you really only need to set the draglink once. If you run a straight draglink with opposing thread at each end, you can just loosen the jam nuts and turn the rod.
That was my best guess, you did a nice job. Thanks for the info.
