Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
  1. #41
    If you don't mind stealing ideas from others Check out this video from Poison Spyder. You can see how they made their brackets. Maybe you'll get an idea for yours. The front is around 8:00 minutes in, the rears around 10:30.
  2. #42
    Texas
    Ringer, No problem. Shutter Bug, Thank you fir the link. I think I see what I need in that video. Here is a little more progress on them. Click image for larger version.
ID:	57383Click image for larger version.
ID:	57384Click image for larger version.
  3. #43
    Texas
    Ringer, I have a couple more question for you. When you put the sheet metal on what was the line you used to trace the temple for where the sheet metal meets the tube? I had a hell of a time getting it weled and ground down without grinding though the sheetmetal seam. I found some info that seemed to point to cutting the templet to 1/3 the diamitor of the tube insted of half. Is that what you did?
ID:	57398Click image for larger version.
  4. #44
    Driving his wife's Jeep
    Ringer's Avatar
    Chardon, OH
    Yep. There is no super easy way to do it. I used poster board to make templates before I cut the 14ga skins. Then it was weld, grind, weld, grind until it was perfect. Yours are looking really good. They are a pain to do as one off's, but cool to have something unique.
    RubiXcon
    No matter what you have, there is ALWAYS a better way to do it.
    My build thread- http://www.jkfreaks.com/forums/showt...ld-up-of-JKarl
  5. #45
    New JK Freak Dynamo138's Avatar
    Peoria, Il
    Outstanding work!
    2015 JK Sahara - Bonnie
    - Teraflex quick release discos, 1.5" leveling kit, 1.25" body lift
    - Rugged Ridge 1.75" wheel spacers, Dash Multi-Mount System
    - ARB twin compressor
    - Rubicon rock rails
    - Pypes Performance Exhaust HGC
    My Jeep's Youtube channel
    https://www.youtube.com/channel/UCg_...r5ssQ/featured
